Go to Post If you squeeze cost out hard enough, any component can become a failure point. - EricVanWyk [more]
Unread 27-01-2011, 22:05
Whateveryousay's Avatar
Whateveryousay Whateveryousay is offline
Team 1683 Techno Titans
AKA: Tony Chen
FRC #1683 (Techno Titans)
Team Role: Mechanical
Rookie Year: 2010
Whateveryousay is an unknown quantity at this point
Team 1683 Base
Hi Everyone, I am the Mechanical team captain of Team 1683, Techno Titans. This is our base so far (pictures taken in the beginning of the work session on Tuesday, 1/25/2011).
We used 1'' by 3'' 1/8'' thick aluminum tubings for the main frame, and 1'' by 3'' 1/4'' thick plate for the side. Inside the tubing, we blocks that drilled and taped on one side, and a through hole on the other side. The through hole hold the block in place in one tubing, and bolts through the other side. All the bolts that are going through the frame has a spacer inside the tube.
What do you guys think?
2011 Peachtree Regional Innovation in Control Award
2011 Peachtree Regional Semifinalist
2010 Peachtree Regional Champion
2010 Peachtree Regional Creativity Award
2008 Peachtree Regional Finalist
2007 Bayou Regional Champion
2006 Peachtree Regional Finalist
2005 Peachtree Regional Quarterfinalist
