Go to Post The manual can be compared to a textbook in school. If you choose not to use your textbook, you are asking to fail classes. - dez250 [more]
Unread 28-01-2011, 16:44
E2207 E2207 is offline
FRC #2207
E2207 is an unknown quantity at this point
Minibot Questions
Instead of making a new post for each question that was about the same mechanical component, I decided to make one post for all.
1) Can we use a clevis and control horn like the ones used in RC Airplanes to Open/Close the hinge mechanism to hold the minibot to the pole?
2) Since coiled metal springs are not allowed on the minibot (http://forums.usfirst.org/showthread.php?t=16517), and our team was planning to use compression springs to keep the "jaws" open until the minibot reached the pole, what substitution with surgical tubing could we use to keep the "jaws" open until the minibot reaches the pole.
3)Could we use polycarbonate pulleys for our closing plunger mechanism. They won't be contributing to any vertical movement, only to guide cable so they can pull the "jaws" close.
