Minibot Falling Solutions
There might be multiple threads of this question, but i would like to make a general one with multiple ideas.
My team today has built a minibot prototype, and it works pretty good. We are running into a problem when the minibot slides down from the top. The minibot moves great upward, but drops like a stone. What are some of your team's ideas on keeping the minibot's downward movement controlled and safe to avoid a hard crash? |
Re: Minibot Falling Solutions
We were hoping that the motor, being geared, would provide enough resistance to falling. Our main concern, though, is getting the motors to stop because I was trying to see how much torque the motors provided by trying to stop the wheel from spinning. Good news: plenty of torque. Bad news: motor began to smoke after a few seconds.
Try putting memory foam at the bottom of your bot. A nice soft landing.
Memory foam isn't on the approved materials list. Your only potential options would be rubber bands, surgical tubing, non-slip pad, or hook and loop fastener.
Double posting so I don't have to edit a post...
Are these minibots falling/dropping just from the weight of the minibot backdriving the motors? I'll admit I haven't looked to see how fast they backdrive, but falling like a stone doesn't seem likely... If this is the case, however, I vote rigging up a light switch to switch the positive lead on one or both motors from the positive battery lead to the motor's negative lead. Instant regen braking and all that. |
We are planning on using a switch to start the climb, and a switch to make the minibot stop at the top, and then move down slowly. I'm sorry "dropping like a stone" is somewhat an exaggeration, but it just doesn't slide down at a slow, safe pace. What do you think now that memory foam is not allowed? |
Memory foam was never on the allowed materials list for the Minibot. However, it's not on the disallowed materials list for the Hostbot.
I had an idea: If the robot's arm just so happened to be up at the end of the match, just so happened to be about 10' tall, and just so happened to have a device at a shoulder joint that would allow any claws to be operated by hand without robot power being turned on, I don't think the refs can use the "special equipment" rule to disallow that being used to bring the Minibot down. It's part of the Robot, after all... |
http://www.chiefdelphi.com/forums/sh...inibot+warning
It explains a solution for prototyping, but not for the real bot. Surgical tubing or something on the bottom might help. |
c/p from team update #6
<G59> TEAMS must retrieve MINIBOTS from the TOWER quickly and safely without special equipment and while standing on the floor after each MATCH. Violation: The FIELD crew will retrieve the MINIBOT if the TEAM does not. A second violation may result in a YELLOW CARD. so you kind of need the minibot to come back down now or you need some really tall team members. |
#11
What if we buy a really long overcoat and have 3 people stand on each other's shoulders, then they wear the coat. It would appear that it is one person, but it's not.
#12
Wrap the coat in tin foil to give that metallic look too
#13
<G43> allows the HOSTBOT to grab the TOWER during DEPLOYMENT.
