Go to Post FIRST is about family, making new friendships, belonging somewhere, doing something you love, and finding out what your real love is in life, so when you're old and wrinkly you can look back at high school and say "This is when I found myself." - Winged Wonder [more]
Unread 05-02-2011, 11:56
herrplotnick herrplotnick is offline
FRC #2239 (Technocrats)
Rookie Year: 2007
herrplotnick is an unknown quantity at this point
Re: Minibot Falling Solutions
The current Rating is 6 AMPs for this pb switch but I assume that is somewhat comparable to a household light switch. The rules specify max a 20 amp fuse so I would think that would be sufficient for current limiting.
Is there anyway I can get a First judge to respond to this?
Also, Is there a detailed list of the Tetrix components on-line? I have failed to find it and I wonder if there is a switch from that list we could use instead.
Unread 05-02-2011, 13:28
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
As with anything else, the only way to get an official opinion is to use the Q&A on the FIRST website. You have to log in with your team ID found in TIMS.
(since 2004)
Unread 05-02-2011, 13:56
Big Ideas Big Ideas is offline
Mentor
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Rookie Year: 2007
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
If you are running 2 motors. It is possible to run them at 1/2 voltage (potentially 1/2 speed) by switching them into series connection instead of parallel connection. This cuts the current thru the motors in 1/2.
