Go to Post Success is the indescribable feeling you get when you see something you worked so hard on in front of thousands of people. - SlamminSammy [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 28-01-2011, 20:47
SeanBurger SeanBurger is offline
FRC #2129 (Ultraviolet)
SeanBurger is an unknown quantity at this point
Unable to image CompactRIO/cRIO
We get this message when we try to image it.
Unable to assign an IP address for the cRIO Device. Ensure the IP Reset Switch on the cRIO Device is turned off.
We believe the IP reset is off. Any suggestions?
Unread 28-01-2011, 21:18
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Unable to image CompactRIO/cRIO
What leads you to believe that the IP reset is off?
Unread 28-01-2011, 23:04
The switch on the cRIO is pressed down on the side that says off and we tried it the other way and that didn't work.
Unread 29-01-2011, 11:55
Kyler Hagler's Avatar
Kyler Hagler Kyler Hagler is offline
Jack of all trades
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2011
Kyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura aboutKyler Hagler has a spectacular aura about
We had the same problem, make sure the safe mode switch is off and you are going through the 1st ethernet port on the cRio.
Unread 29-01-2011, 14:02
Safe mode is off and we are connected to Ethernet port 1and we get the same message.
Unread 29-01-2011, 21:11
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Always image while "hard wired" (tethered) and not wireless. Try turning off the wireless adapter in the pc doing the imaging so that it only has one network adapter. Fix the ip address of the pc to 10.x.x.6 (where x.x is your team number) Sometimes the imaging software will try to use the wrong network adapter. This may not be it but something to try.
Brian K
Team 1225 Robotics Mentor
