Go to Post All we know is the "Oh my God, No data/Radio...reset...reset" dance before our matches! - tenfour [more]
Unread 28-01-2011, 22:13
takiko1996's Avatar
takiko1996 takiko1996 is offline
FRC #2443 (Blue Thunder)
Rookie Year: 2011
takiko1996 is an unknown quantity at this point
Pneumatics piston
Can we use a Pneumatic piston that is not hooked up to any tubes or air compressors as a shock absorber?
Unread 28-01-2011, 22:17
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Re: Pneumatics piston
!!!!NOT AN OFFICIAL ANSWER!!!
As I understand it, as log as the ports are not plugged, it would be legal. You could put adjustable needle valves in the ports and adjust them to allow air in at out at a rate that you like, but if you plug either end, you create the potential to compress air to a higher than legal pressure.
Former Mentor Team 1771
Former mentor Team 4509
Unread 28-01-2011, 22:41
takiko1996's Avatar
Rookie Year: 2011
Thank you very much!
We were also wondering if you would know how we can get an official answer, or get this confirmed.
Thanks,
Unread 28-01-2011, 22:47
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Thanks,
Ask the FIRST Q&A.
Unread 28-01-2011, 22:49
earlybird's Avatar
earlybird earlybird is offline
They tried to ship me 2 competition
AKA: Robbie Oehrli
FRC #2849 (Team Ursa Major)
earlybird is a jewel in the roughearlybird is a jewel in the roughearlybird is a jewel in the rough
To get an official answer straight from the GDC go to the Q&A forum on the FIRST website.
http://usfirst.org/roboticsprograms/...nt.aspx?id=456
Unread 29-01-2011, 00:14
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Rookie Year: 2007
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Alternatively you could use a sealed pneumatic (gas) shock as discussed in <R66-H>. They are available cheaply from McMasterCarr:
http://www.mcmaster.com/#gas-shocks/=asncje
Unread 29-01-2011, 09:54
DonRotolo's Avatar
Back to humble
FRC #0832
To expand upon Martin417's answer: You connect one port of the cylinder to the other port, using approved tubing and connectors. One of the connectors can be a needle valve to adjust the force required. You can also then use a spring (such as a length ot latex tubing) to return the piston in the cylinder to some desired position to ready it for another 'hit'.
Unread 29-01-2011, 10:03
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
This is the defining rule in part...
<R69> Compressed air for the pneumatic system on the ROBOT must be provided by one and only one compressor...
Compressed air shall not come from any other source.
And R66
H. For the purposes of the FRC, closed-loop COTS pneumatic (gas) shocks are not considered pneumatic devices, and are not subject to the pneumatic rules (although they must still satisfy all other appropriate rules).
Al
WB9UVJ
www.wildstang.org
________________________
Unread 29-01-2011, 17:30
Android's Avatar
Android Android is offline
Team Role: Photography
Android is an unknown quantity at this point
The FIRST Q&A proves to be very slow. Does anyone have any other suggestions?
Unread 29-01-2011, 17:57
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Ask sooner, rather than later.
They are the ONLY official source of rulings.
Unread 04-02-2011, 00:51
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Slow they may be, but sure they are.
Pneumatic pistons used in the way described are not legal. Reason not given, but I would suspect Al's reasoning is correct. http://forums.usfirst.org/showthread.php?t=16749
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 04-02-2011, 13:57
Android's Avatar
Yes, thank you. That was me posting it.
Unread 04-02-2011, 14:43
martin417's Avatar
AKA: Martin Wilson
I question that answer. I haven't seen an answer from the GDC that did not cite a rule before, and I can't find a rule that this would violate. You might post a follow up question asking what specific rule it violates so you can modify your design to alleviate the violation.
Unread 04-02-2011, 17:49
Android's Avatar
Exactly, one of my colleagues and I derived another question that follows up our previous question. Referencing the possibilities from this thread, along with the rest of the resources @ Chief Delphi.
