Go to Post This game is all about dealing with the unexpected and making changes on the fly. - Greg Hainsworth [more]
Unread 29-01-2011, 00:30
ehlochbr ehlochbr is offline
FRC #2990
ehlochbr is an unknown quantity at this point
Invalid Conversion
Hi everyone,
This is probably an easy one but I'm just not seeing the answer. I'm trying to incorporate code for the IR sensors and everything seems fine except for one little error that says "invalid conversion from "int" to "DigitalInput."
Here's a snapshot of some of the code.
Code:
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Gamepad controller;
	Jaguar one;
	Jaguar two;
	Jaguar three;
	Jaguar four;
	DigitalInput *left;			// digital inputs for line tracking sensors
	DigitalInput *middle;
	DigitalInput *right;
	DriverStation *ds;
	AxisCamera& camera;
public:
	RobotDemo(void):
		myRobot(9, 10, 2, 1),	// these must be initialized in the same order
		controller(1),
		one(9),
		two(10),
		three(2),
		four(1),
		left(1),
		middle(2),
		right(3),
		ds(DriverStation::GetInstance()),
		camera(AxisCamera::GetInstance())
	{   <------- ERROR HERE
		GetWatchdog().SetExpiration(0.1);
Thanks for your help!
Unread 29-01-2011, 02:29
shandrin shandrin is offline
AKA: Shan Johnson Sevcik
FRC #0057 (The Leopards)
shandrin is a jewel in the roughshandrin is a jewel in the roughshandrin is a jewel in the roughshandrin is a jewel in the rough
Send a message via AIM to shandrin
Re: Invalid Conversion
The problem is that you're declaring pointers to DigitalInputs, and then trying to initialize them in the initialization list. You either need to declare them as actual DigitalInput objects (no *) or instead of left(1), middle(2), right(3), you need to have inside the constructor (where you note "error here"):
left = new DigitalInput(1);
middle = new DigitalInput(2);
right = new DigitalInput(3);
Hope that helps!
