Go to Post I believe that those who have a clear understanding of their capabilities, both physical and financial, and design and build within those capabilities are the teams that succeed. - Daniel_LaFleur [more]
Unread 29-01-2011, 10:14
Arthur But' Arthur But' is offline
FRC #2213
Arthur But' is an unknown quantity at this point
What VI to use with the line detector?
well....what VI do i need to use with the line detector?
and i would like someone to show a simple example of how to use it correctly.
Unread 29-01-2011, 14:32
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: What VI to use with the line detector?
Like with any sensor you would open a DIO in your begin (whatever D Sidecar port you have it in). It puts out a 2 digit binary 10 or 01 im not sure which is lightness and which is darkness but thats the vi. if you need an example the autonomous code that is default in the project has it working with descriptions.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 30-01-2011, 11:07
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
In case j.cole wasn't clear enough, I'll expand on what he said. The photosensors connect to a DIGITAL I/O pin on the Digital Sidecar. Only one of the black or white wires needs to be connected; one of them provides a signal when the photosensor is detecting an object, and the other provides a signal when it is not. Those pins are read using the DIO In functions (WPI Robotics Library >> IO >> DigitalInput).
The Robot Framework with Game Code project shows you how to use three photosensors to follow a gray line on the carpet. It's all in the Autonomous Independent vi.
Unread 02-02-2011, 12:13
IisMathwizard's Avatar
IisMathwizard IisMathwizard is offline
Programming Mentor
AKA: Mathwizard
FRC #1248 (Titanium Allies)
IisMathwizard is an unknown quantity at this point
IDK if this will help but this is how my mentors explained this to me...
Because the photosensor doesn't have its own coding it doesn't need its own VI. It is just a DIO and thats all that is required, although a DIO get vi is still needed...
(I put that in there because i accidently made the mistake of forgetting the Get vi.)
jRIO 2013 Project
