Go to Post Every robot needs a locky-thingy. A robot without one might fire when it isn't supposed to, and hit the wrong target; e.g., a referee, FTA, or robot inspector. - Richard Wallace [more]
Unread 29-01-2011, 12:37
Team 3705's Avatar
Team 3705 Team 3705 is offline
FRC #3705
Team 3705 is an unknown quantity at this point
Potentiometers C+
Our team is trying to find a way to measure the position of our arm using a potentiometer. We're using C++ we can't find any programs for potentiometers.
Does anyone know the best way that we could program a potentiometer in C++ to give us its position?
-Thanks
Unread 29-01-2011, 15:28
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: Potentiometers C+
Potentiometers are an analog sensor. As such they would be plugged into the analog module on the cRIO. You should look at the analogchannel class, and the GetVoltage function within that class. You will have to multiple the voltage by some value, to get how far the pot has turned. This value can probably be found in the spec sheet for the POT.
