Go to Post If something on your robot isn't working, then why don't you take the responsibility to fix it? Isn't that what being a TEAM is all about? - dlavery [more]
Unread 29-01-2011, 20:52
AceofSpades49 AceofSpades49 is offline
FRC #2477
AceofSpades49 is an unknown quantity at this point
Fixing 2011 Axis Camera
I configured the 2011 Axis Camera manually and wrote code to test it's vision. When I wired the camera up and turned the circuit on the camera was not getting power. Then when I plugged it into an outlet the camera still did not get any power. Can anyone please suggests any solutions or any explanations on why this happened?
Unread 30-01-2011, 08:35
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Fixing 2011 Axis Camera
Possibly you reversed the power or connected it to 12v instead of the special 5v output when wiring it to the PD and burned the camera. Double check the barrel connector polarity and 5v with a multi-meter.
Unread 30-01-2011, 09:29
ziggyfrommahrs ziggyfrommahrs is offline
FRC #3716
ziggyfrommahrs is an unknown quantity at this point
This happen to us as well. We spoke to Axis, opened a RMA and sent it back so they could examine the camera. The camera's are still under warranty.
Unread 02-02-2011, 18:58
FRC #2477
Thank you for the reply. We will check on the camera again and call Axis if needed.
