Go to Post The moral of this story is that constructive criticism is good, but only as long as you don't act like a complete idiot. - David Kelly [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 29-01-2011, 21:57
KC1AJT's Avatar
KC1AJT KC1AJT is offline
Head Mentor
AKA: Patrick
FRC #6617 (Bellinghan High School Black Hawks Robotics Club)
KC1AJT is an unknown quantity at this point
Scouting System - need Samba help
Ok I can't give many details here, but I promise that when it's finished, I will release it. I need some Samba help on a CENTOS server...let's just say it has a database on it I have Samba all configured with users and a share as well as firewall access. On the Windows PC, when I go to access the share it comes up with the attached screen. No password works and I cant change the user. Is there a config file somewhere that can fix all this?
Mentor - Team 6617
_____________________________________________
Student Years - Team 61
2011 Boston Regional
2011 BAE Systems/Granite State Regional
2010 Northeast Utilities FIRST Connecticut Regional Finalist
2010 Boston Regional
2009 Archimedes Division
2009 Connecticut Regional
2009 Boston Regional Regional Winner
Unread 30-01-2011, 09:26
rdlevy1215's Avatar
rdlevy1215 rdlevy1215 is offline
FRC #1676 (Pascack Pi-oneers)
rdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud of
Re: Scouting System - need Samba help
Since you are using Windows XP, make sure that you have Simple File Sharing turned off. This can be accomplished by going to any explorer window, pressing Tools, and going to the last option "Folder Options." Once there, go to the "View" tab and scroll until you see something that says Simple File Sharing, and make sure you select "Do Not use Simple File Sharing."
After you have done this, try reconnecting to your SMB server with the proper credentials (SERVERNAME\username for the username, and then whatever password you set).
Good Luck!
Robert D. Levy
Mentor
Team 1676, "Pascack Pi-oneers"
http://www.team1676.com/
admin@team1676.com
Unread 30-01-2011, 11:16
KC1AJT's Avatar
Head Mentor
AKA: Patrick
All fixed found out that the database itself cannot be used as a share in Samba, but instead has to be in a folder that is shared. All set now!
Mentor - Team 6617
Unread 30-01-2011, 12:13
KC1AJT's Avatar
Head Mentor
AKA: Patrick
Ugh oh. New problem. When you open a database file using OOBase, it locks the file so that only you can view it. Is there a quick hack or something to make OOBase accept multiple user inputs?
Mentor - Team 6617
