Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 01-30-2011, 10:38 PM
ahollenbach ahollenbach is offline
AKA: Andrew
FRC #0103 (Cybersonics)
Rookie Year: 2010
ahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to all
Help with search results
Hi, I'm Andrew from Team 103, and I'm head of website this year. You can check out our site at www.cybersonics.org.
I have a question in regards to changing search result data. If you Google "cybersonics", you can see that the blurb about the team is simply a list of submenu options we have. Needless to say, this is not what we want people to see when they Google us!
My solution to the problem, I think, is to create a <meta> tag with a content="Cybersonics is...blurb here" on our index page. Is this the right way to do this?
Thanks in advance for your help!
Unread 01-31-2011, 12:15 AM
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: Help with search results
Yep, create a 'description' meta tag with a description that clearly and accurately describes the page. (Ideally, each page should have a unique description, so avoid using the same one for the entire site.)
Code:
<meta name="description" content="Cybersonics is a really great robotics team..." />
You can't guarantee that Google will show that description in the search results, but it's worth a try.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 01-31-2011, 07:03 PM
AKA: Andrew
Rookie Year: 2010
Thanks!
Also, cute description
