Go to Post Maybe next season I want to develop and test a new metric for FRC scouting: Bumper Quality Rating (BQR). BQR-5: The platonic ideal of FRC bumpers. ... BQR-0: Moderate to heavy use of duct tape. I believe BQR would outperform OPR as a predictor of on-field robot performance. - Nate Laverdure [more]
Unread 31-01-2011, 13:26
mbone206 mbone206 is offline
FRC #0223
mbone206 is an unknown quantity at this point
Labview Camera lag -- modify dashboard
Last year there were a lot of problems with running robot using the camera, lag and TCP errors. I know teams created new dash boards to eliminate some controls. I read the dash board tutorials, I still need a little assistance. If I want to just use camera and some large digital input Boolean LEDs, what will I have to do. The tutorial indicated an alternate way to send data to dash board is modifying the DashboardEnalbles.ctl. Is this the better way to minimize data flow from Robot, in the end, do not want to have robot lag using camera and controls. I assume this is the front panel? I do not see this control in project window. Do I just delete all the controls on front panel, but still leaves a lot of code. I know there is a dashboard.exe located in C:\Program Files\FRC Dashboard.. Does this exe change when build new dash board? How do you build/create .exe file, I did not see this in tutorial.
Your help will be greatly appreciated
