Go to Post C'mon you guys you're all inventors. You guys should be making a portable cryogenic sleep chambers for those long bus trips! You got two weeks before you have to go. Get cracking! - Koko Ed [more]
Unread 31-01-2011, 20:22
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
Connect Team Laptop to Home Wireless Problem
My home network has a MAC address filter list for the wireless devices. I want to add the MAC addresses of the team laptop and the netbook to the list.
I have a linksys wrt54g and for some reason it won't let me connect directly to the router from my PC, which is connected by tether to the router. I open up command prompt and type 'ipconfig /all' and find that my default gateway is 192.168.1.1. when I attempt to navigate to that address through my web browser i get a message saying that "the webpage is not available".
Any ideas on how to connect to my router to change my Mac filter? I have internet connectivity and am able to browse the internet and everything on my PC just not able to connect directly to the router. Any ideas?
I need Internet access to install and update properly.
~Team 1529 Cybercards~
Unread 01-02-2011, 09:33
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Connect Team Laptop to Home Wireless Problem
Check to see if the IP address of the PC is compatible with a 192.168.1.yy address.
If you ran the Driver Station application it may be on the private 10. network.
You can try manually setting the PC address to 192.168.1.xx
Unread 01-02-2011, 12:02
FRC #1529
It works now! thanks!
