Go to Post We could not make weight so we got rid of the cRIO. - Mike Copioli [more]
Unread 31-01-2011, 20:36
MikeNimmo's Avatar
MikeNimmo MikeNimmo is offline
Software
FRC #3126 (Flashpoint)
Rookie Year: 2010
MikeNimmo is an unknown quantity at this point
ZomB Dashboard unresponsive
Our team has recently been thinking about using the ZomB Dashboard. We just downloaded ZomB Version 0.7.1.350 and are using the SimpleRobot.cpp code with the ZomB header file and additions suggested here. After throwing the code into our cRio we found the "taco", which is supposed to move in accordance to the y value of the joystick, not budging no matter how much we beat on our joystick. Can someone help us resolve this? The text we got from NetConsole is attached as a .txt file below.
Unread 01-02-2011, 12:29
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: ZomB Dashboard unresponsive
Did you also install it? or more specifically, the new ZomB.out? this looks like WPILib version mismatch spew. Go to Start>Programs>ZomB>Install bindings to robot, enter your ip, install, reboot the robot, and try again. If it still does this, look at Start>Programs>ZomB>Binding Help, the section "C++ (DBPacket workaround)" and try that.
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 03-02-2011, 21:30
MikeNimmo's Avatar
Software
Rookie Year: 2010
We fixed it! The problem was that we were using the default dashboard image installation gave us. It worked fine as soon as we made our own dashboard image and used that.
