Go to Post You will forever be confronted with choosing between right and wrong, or choosing what you think you can get away with. Which way you go defines what kind of person you are. Choose wisely. - Gary Dillard [more]
Unread 31-01-2011, 22:25
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
Faulty Jaguars (CAN)
We have had a run of bad Black Jaguars.
Several were bad immediately out of the box (no light; no response to BDC-COMM). Others went bad in the same fashion as soon as they were placed in a CAN network on the bot. At least two more appeared responsive (lights on and individually responsive to to BDC-COMM) but would not respond on the network. (Cable and terminators have been checked and swapped.)
None of the bad Jaguars ever turned a motor. All were purchased from Digikey.
The ones that have worked have worked without incident.
Has anyone else been experiencing similar problems?
