Go to Post Certainly more interesting to watch than driving around in circles on a flat field. Sorry, 2008. - synth3tk [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 31-01-2011, 23:25
reddprogram reddprogram is offline
FRC #3155
reddprogram is an unknown quantity at this point
ROOKIE Programmer- no Green for Robot Code on LABView Driver Station
When I try to enable the driver station to test out new codes the robot code is red, and the driver station does not allow access control to teleop. Why is it not green, if anyone can respond with info it can help. thanks
Unread 31-01-2011, 23:36
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
Re: ROOKIE Programmer- no Green for Robot Code on LABView Driver Station
If any of the indicators to the left of the enable/disable buttons are a dull green, you cannot enable. You need the USB stop button connected, you need to have your driver station connected to the robot, and you need robot code loaded from a separate computer (or whatever). Which ones are lit?
Unread 01-02-2011, 00:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Can you describe the steps you are taking to try to get your program to run? Be as detailed as possible. We might notice something that you're doing wrong, or failing to do, that would keep it from succeeding.
Unread 01-02-2011, 08:16
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
If you haven't areledy you might want to check out some of the documentation that FIRST gives you about the driver station. http://www.usfirst.org/roboticsprogr....aspx?id=18530
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 01-02-2011, 10:44
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
Ensure that your labviwlew and driver station files are up to the most up to date version. Also, ensure that when you deployed the code, the deployment status window (the small window that pops up) says that deployment is successful. If you need to update, update labview first, then your labview util, then your driver station and redeploy the labview code again. Hope this fixes your problem.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Unread 02-02-2011, 17:55
dotbran dotbran is offline
AKA: Brandon Olsen
FRC #3219 (TREAD)
Rookie Year: 2010
dotbran is on a distinguished road
Make sure that you Build All then Run As Startup rather than just doing a Deploy.
Unread 04-02-2011, 17:31
FRC #3155
Thanks for the information guys, I opened the frc imaging tool and configured my controllers after that i rebooted and deployed the crio, now the robot code communications, and stop button are green. XD
