Go to Post The only basis on which a team should be awarded the chairmans award is the content of the submission, not the way in which it is presented. - KenWittlief [more]
Unread 01-02-2011, 00:45
AgataSays AgataSays is offline
FRC #3553
AgataSays is an unknown quantity at this point
double check
just to double check so that we dont break anything:
to follow up on this thread: http://www.chiefdelphi.com/forums/sh...d.php?p=914640
to connect the valve to the solenoid breakout, we cut the "2-wire jumper cable" in half, connect the white wire to the black on the solenoid, and the red to the red on the solenoid, and the extra wire that is not covered in plastic just cut it away or ground it?
