Go to Post 30 point hang is brutal. Those who say it is easy are not thinking it through or are way smarter than the rest of us ... - Paul Copioli [more]
Unread 01-02-2011, 13:08
Dave Bush Dave Bush is offline
FRC #0801
Dave Bush is an unknown quantity at this point
How to use "Sync Groups"?
Can't find much info on how "Sync Groups" work with CAN based motors? The online help really doesn't help. What does the Sync value represent? The address of the motor you want to send the same command to? If so is it possible to sync more than one motor?
Current config: 2Can, LV, dual motor drive (i.e. two motors, one gearbox per side).
Unread 05-02-2011, 16:43
lior_regev lior_regev is offline
FRC #2630
lior_regev can only hope to improve
Re: How to use "Sync Groups"?
I'de love an example too please
Unread 07-02-2011, 13:47
Talguy Talguy is offline
FRC #2168
Talguy is an unknown quantity at this point
when your setting the output using the "motor set output" vi, you can create a constant for the sync group. This constant is defines what sync group the motor will be in for that update cycle. After all you motors are set to their desired outputs call the "Jag update sync group". This last command will tell all the jags in that group to accept the output values and start adjusting that motor speed all at the same time.
Unread 08-02-2011, 02:12
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
That's mostly correct. The only correction is that the group is an 8-bit mask. This means you could call set output and assign a sync group of 3 and then pass 1 or 2 into Update Sync Group and and the update would be applied in either case. You could also assign one motor to 4 and another to 8 and then pass 12 into Update Sync Group and both motors will update.
Not sure why you would want to do any of this, but that's how it works. Just don't accidentally use group 2 and 3 and expect them to be independent.
-Joe
