Go to Post A big bowl of popcorn and FIRST. It doesn't get much better than that. - Warren Boudreau [more]
Unread 01-02-2011, 18:20
JamieSimonson JamieSimonson is offline
FRC #1389
JamieSimonson is an unknown quantity at this point
Smile Lego Programming?!
I was wondering if the lego touch sensor could be programmed using C++ (windriver) or does it only work using the NXT brick and that sort of programming. Can you Help?
Unread 01-02-2011, 18:23
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: Lego Programming?!
{As an FTC programmer, I can tell you that the closest to C++ and Windriver you'll get with the NXT is RobotC. If you have an FTC team in the area, they have a license. There's also a 30 day trial, if you want to test it.
I am unaware if there is a way for FRC teams to get it free/cheap without an FTC team to lend it, though.}
EDIT: Wow, misread/misunderstood the question. I'm going to go away now, until I can test it out.
EDIT 2: Looks like a couple of things. The default output appears to be I2C using the cables provided. So, if you can figure that out, you can probably get the cRIO talking that way. DIO would be your friend. Alternatively, you can crack the thing open, and solder on two wire leads, then close it again. How To Do It. Then it should be usable for both.
Of course, if you go through the trouble of opening it, you may as well just use a momentary pushbutton, unless the enclosure is important.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 01-02-2011, 18:28
RoboDesigners's Avatar
RoboDesigners RoboDesigners is offline
VRC #2190 (RoboDesigners)
Team Role: Leadership
RoboDesigners will become famous soon enoughRoboDesigners will become famous soon enough
A touch sensor should just be a digital signal: 1 or 0. Treat it just like any other touch sensor.
EDIT: Is the sensor connected to the NXT, or to another controller?
Visit my website! www.RoboDesigners.com
VRC Team #2190
Twitter: @RoboDesigners
Unread 02-02-2011, 02:18
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
There is a port for LEGO sensors on the digital sidecar. We program in labview, but it should be easy enough to use it.
Unread 02-02-2011, 09:54
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The NXT port on the digital sidecar is for I2C NXT sensors. The touch sensor is simply a switch and so should be connected to the digital IO, just like any other switch. Making an interface cable might be a pain.
Connect pin 1 of the touch sensor to the signal pin of the DIO and pin 2 of the touch sensor to ground, and you're set.
Unread 02-02-2011, 10:17
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
Rookie Year: 2007
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Based on prior FTC and LEGO experience with these sensors, I would highly recommend buying a cheap microswitch. It would probably be easier to mount, and would definitely be easier to interface.
What is the application for this touch sensor?
