Go to Post DO NOT THROW THINGS AT THE PROGRAMMER! - demosthenes2k8 [more]
Unread 02-02-2011, 07:11 PM
IisMathwizard's Avatar
IisMathwizard IisMathwizard is offline
Programming Mentor
AKA: Mathwizard
FRC #1248 (Titanium Allies)
IisMathwizard is an unknown quantity at this point
Lightbulb Nullifier Button: Yay or Nay
Our team came up with the idea to make a nullifier button that would, when pressed, stop all joystick and dashboard control. It's similar to the stop button but doesn't permanetly stop communications. Its a button on the joystick that when pressed activates case structures that will set x and y axis values for arcade drive to 0 and also 0 for the arm motor. My question: Is a nullifier button allowed? or is the stop button only allowed.
The objective of the nullifier button is to allow us to temporarily stop during a match to fix any "quick fix" problems we may have. Also, it will definately help out during testing if i made any screw-ups in the code.
jRIO 2013 Project
Unread 02-02-2011, 07:16 PM
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Nullifier Button: Yay or Nay
There would be nothing illegal about this; to the field, it is the same as any other drive input/command.
We use this during software testing, as we hate having to deal with the actual stop button.
Unread 02-02-2011, 07:17 PM
Programming Mentor
AKA: Mathwizard
Our team came up with the idea to make a nullifier button that would, when pressed, stop all joystick and dashboard control. It's similar to the stop button but doesn't permanetly stop communications. It's a button on the joystick that when pressed activates case structures that will set x and y axis values for arcade drive to 0 and also 0 for the arm motor. My question: Is a nullifier button allowed? or is the stop button only allowed.
The objective of the nullifier button is to allow us to temporarily stop during a match to fix any "quick fix" problems we may have. Also, it will definately help out during testing if i made any screw-ups in the code that could create mechanical or structural damage.
jRIO 2013 Project
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
I believe this is allowed, because this is all programming, not an actual physical device you brought in.
Unread 02-02-2011, 07:21 PM
alexhenning alexhenning is offline
WPILib Developer
FRC #0348
alexhenning will become famous soon enough
I don't see why you wouldn't be allowed to in addition to the stop button. The purpose of the stop button is safety, but there's nothing limiting what you can do with controls, as long as it doesn't cause your robot to do something illegal.
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
A good idea, but you may want to disable this for competition. I could see drivers becoming angry if they accidentally pressed a button at the start of teleop and the robot became unresponsive.
Maybe an alternate idea would be an "enable button". The robot would only operate as long as the driver holds down a button.
Unread 02-02-2011, 07:25 PM
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Of course you can create a local e-stop (I'd recommend it!) It's really great for testing in the shop (especially before the days of the included e-stop button), and you're right, once you hit the button on the field, you're done for the match.
Jacob
Unread 02-02-2011, 07:32 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I'm not aware of any rules that prevent you from using Driver Station controls to do anything you want to do.
During testing, why not just use the space bar to disable the robot when necessary? It's just like clicking the "Disable" button on the screen.
Unread 02-02-2011, 09:30 PM
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Threads that were started with almost identical posts have been combined.
(since 2004)
Unread 02-03-2011, 03:56 AM
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
We actually programmed our custom stop button to activate a PID control loop to keep the robot in one position. If someone bumped into us, the encoders would measure how far we moved and try to move us back into position.
In pre c-rio days it was a handy feature when doing public demos... you could let a kid drive your robot while a team member kept their hand over the stop button.
Jason
