Go to Post Just because you haven't witnessed parts leaving the flywheel yet, doesn't mean it won't happen. - Al Skierkiewicz [more]
Unread 02-02-2011, 09:03 PM
Lawlhwut Lawlhwut is offline
None #2853
Lawlhwut is an unknown quantity at this point
Autonomous Not Working
Code:
#include "WPILib.h"
class RobotDemo : public SimpleRobot
	// Declare Motors
	RobotDrive myRobot;
	Victor LeftDrive;
	Jaguar RightDrive;
	Jaguar Lift;
	Jaguar Claw;
	// Declare Joysticks
	Joystick LeftStick;
	Joystick RightStick;
	// Declare Sensors
	Encoder LeftEncoder, RightEncoder;
	Gyro gyro1;
	static const float Kp = 0.03;
public:
	RobotDemo(void):
		// Set Channels
		myRobot(1,2),
		LeftDrive(1),
		RightDrive(2),
		Lift(5),
		Claw(4),
		LeftStick(1),
		RightStick(2),
		LeftEncoder(3,4,true),
		RightEncoder(5, 6, true),
		gyro1(7)
			// Set Motor Expiration
			LeftDrive.SetExpiration(0.005);
			RightDrive.SetExpiration(0.005);
			Lift.SetExpiration(0.005);
			Claw.SetExpiration(0.005);
			// Set Encoder Displacement Values
			LeftEncoder.SetDistancePerPulse(0.26333);
			RightEncoder.SetDistancePerPulse(0.26333);
	void Autonomous(void)
		//Delcare variables
		int AutoStep = 1;
		// Start sensors
		LeftEncoder.Start();
		RightEncoder.Start();
		gyro1.Reset();
		// Run while in autonomous mode
        while(IsAutonomous())
        	// Return sensor values for tracking
        	float leftdistance = LeftEncoder.GetDistance();
        	float rightdistance = RightEncoder.GetDistance();
        	float angle = gyro1.GetAngle();
        	// Update LCD with new data
        	DriverStationLCD *screen = DriverStationLCD::GetInstance();
        	screen->PrintfLine(DriverStationLCD::kUser_Line1,"Left Motor",LeftDrive.Get());
        	screen->PrintfLine(DriverStationLCD::kUser_Line2,"Right Motor",RightDrive.Get());
        	screen->PrintfLine(DriverStationLCD::kUser_Line3,"Direction",gyro1.GetAngle());
        	screen->UpdateLCD();
			switch(AutoStep)
				case 1:
					// Move forward to set position
					myRobot.Drive(1.0, -angle / Kp);
					Wait(0.005);
					// Stop if distance is reached
					if(leftdistance >= 4953 || rightdistance >= 4953)
						LeftDrive.Set(0);
						RightDrive.Set(0);
						AutoStep = 2;
					break;
				case 2:
					// Drop tube
					Claw.Set(1.0);
					Wait(1.0);
					Claw.Set(0);
					AutoStep = 3;
					break;
				case 3:
					// Adjust for gameplay
					LeftDrive.Set(-0.5);
					RightDrive.Set(-0.5);
					Wait(1.0);
					while(gyro1.GetAngle() > -180 || gyro1.GetAngle() < 180)
						LeftDrive.Set(-0.25);
						RightDrive.Set(0.25);
						Lift.Set(-1.0);
						Wait(0.1);
					break;
	void OperatorControl(void)
		// Reset motors for teleoperator
		LeftDrive.Set(0);
		RightDrive.Set(0);
		Lift.Set(0);
		Claw.Set(0);
		gyro1.Reset();
		// Run while in operator control mode
		while(IsOperatorControl())
			// Get Drive
			float lefty = (LeftStick.GetY());
			float righty = (RightStick.GetY());
			// Desensitize joysticks
			lefty = ((lefty/128)*(lefty/128));
			righty = ((righty/128)*(righty/128));
			// Set Drive
			LeftDrive.Set(lefty);
			RightDrive.Set(righty);
			// Claw Control
			if(RightStick.GetRawButton(2))
					Claw.Set(1.0);
			else
				if(RightStick.GetRawButton(3))
					Claw.Set(-1.0);
				else
					Claw.Set(0.0);
			// Lift Control
			if(LeftStick.GetRawButton(2))
				Lift.Set(1.0);
			else
				if(LeftStick.GetRawButton(3))
					Lift.Set(-1.0);
				else
					Lift.Set(0.0);
			screen->PrintfLine(DriverStationLCD::kUser_Line1,"Left Motor:",LeftDrive.Get());
			screen->PrintfLine(DriverStationLCD::kUser_Line2,"Right Motor:",RightDrive.Get());
START_ROBOT_CLASS(RobotDemo);
Builds flawlessly, but when we try to run it on our prototype robot, the communication is lost and the robot acts funky.
Solutions?
