Go to Post Im very proud of my kids, and my whole team, the passion and emotion here is what FIRST is all about :) - Kims Robot [more]
Unread 02-02-2011, 21:33
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Rookie Year: 2010
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Team 1716 forklift arm- preliminary design
This is a quick video of team 1716 Redbird Robotics design for our arm. We call it a forklift arm due to its movement. Please comment and tell what you think of it. We do not quite have our tube grasper working because we need to connect the pneumatics. The lift is a bit shaky but that is being improved. Enjoy!
http://www.youtube.com/watch?v=9VmLtzp7Akc
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 02-02-2011, 22:45
phoenix_fire's Avatar
phoenix_fire phoenix_fire is offline
FRC #2489 (Insomniacs)
phoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the roughphoenix_fire is a jewel in the rough
Re: Team 1716 forklift arm- preliminary design
You might want to add some supports to the base stage of the lift to limit the shaking. Other than that, it looks like it works pretty nicely!
FRC 2489 Insomniacs
FTC 548 & 596 Geek Squad and Transformerz
Unread 02-02-2011, 22:48
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
i know its still sort of a prototype, but you do you that you have to start in the frame perimiter at the start of the match dont you?
Unread 02-02-2011, 23:06
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
It does start within the frame... the whole mechanism is mounted on sliders that are pushed out when the match starts.
As far as the oscillation, that is a problem being worked on.
we are always open to suggestions!
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 02-02-2011, 23:11
AKA: Garty
Sounds like a great design to me!
Unread 02-02-2011, 23:13
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
We have a similar design, but is stabilized by it being two pieces, with our grabber running as a sort of car in front of them. We call it the Elevator!
Unread 02-02-2011, 23:27
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
It needs more triangles. Although that may prove difficult if that's the only part sliding forward... But the bigger the triangle, the less leverage the lifter will have to torque the base.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 02-02-2011, 23:33
Chris is me's Avatar
AKA: Pinecone
I'd put a diagonal support on the base piece of extrusion - you can put that diagonal support on a slider too!
Unread 02-02-2011, 23:55
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
I'm quite curious to know what you are using to propel your lift up. My team is using a similar concept, but we haven't quite worked out all of the bugs (like how to store cord around a spool effectively.)
Last edited by nitneylion452 : 02-02-2011 at 23:56. Reason: corrected grammatical error
Unread 04-02-2011, 23:31
AKA: Simon Bohn
Rookie Year: 2010
Couldn't you just drill a hole in the spool, and tie a knot in string, so that it sticks in? Tension it with the proper amount, and you should have no problems with keeping it on. As long as you have some sort of hardware stop (ie, potentiometer, or limit switch), that stops your winch from turning when it reaches bottom.
Unread 05-02-2011, 02:05
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
Team Role: Coach
Rookie Year: 2007
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
That could probably be fixed with 2 cables. At the start of the match they could be loose then once the slide is pushed forward they become taught and act as trussing members. Just a simple fix that might be worth a shot =)
Unread 05-02-2011, 07:29
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Have you tried it with BUMPERS in place?
(since 2004)
Unread 05-02-2011, 09:36
McGurky's Avatar
Geek
AKA: Kyle McGurk
Just to update everyone on the progress
Yesterday we finished our supporting frame for the arm and got it all mounted, and it makes mountains of difference. While the forklift does shake a bit at the top, it is nothing major like what you see in the video.
Winch: Powered by two window motors(on spikes). It simply spools the length of 1/16th inch cable needed, nothing simple. Currently there is no down-drive that is connected, but we do have one member finishing it up(much more complex than expected)
Bumpers: Like stated earlier, the entire mechanism is mounted on the KOP Igus Drylin sliders. In total, the entire mechanism slides from within the frame(in starting configuration) to about 2.5 inches outside the frame perimeter(and past the bumpers), allowing the final stage of the forklift to extend fully to the ground to pick up tubes. The whole system has a total draw of 11inches from fully retracted to fully extended with final stage on the floor.
Hopefully we can get up a video on Monday of the entire mechanism and how it works (a video is worth a million words).
Hope this helps answer some of the burning questions!
-McGurky
Unread 13-02-2011, 13:37
Rookie Year: 2010
Thanks to all of the previous commenters! We have the robot mostly finished, and are much farther along than we were at this point last year. Here is a video showing our progress:
http://www.youtube.com/watch?v=IEgJBFJEcKg
Our minibot deployment is also coming along well. We have built our core system and still have some work to do. Here is a video of that as well:
http://www.youtube.com/watch?v=QTh59TiHde4
Enjoy!
