Go to Post For me, FIRST is inspiration with a positive feedback loop - it just keeps getting better. I wonder where it will go from here... - petek [more]
Unread 02-02-2011, 22:15
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
1726 arm prototype video
We finally got our robot working in prototype form. We need to make things a little more substantial....watch the video and see why
http://www.youtube.com/watch?v=3vY2_h2GBIs
Unread 02-02-2011, 22:17
Brandon_L Brandon_L is offline
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Re: 1726 arm prototype video
What material is the arm?
And nice inside-of-tube grabber
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 02-02-2011, 22:20
MrForbes's Avatar
AKA: Jim
Arm is 2" abs sewer pipe, with an extension of 1.5" abs at the end which slides out about 18" at the start of the match (gravity powered). We still need to play with the geometry, I dont know if it'll reach the floor where we want and also score the top goal. And fit that pesky 84" cylinder.
Unread 02-02-2011, 22:53
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
i hope you have better luck with the grabber than my former team did on 07. they used an identical design, and it always was getting hung up on the "foot". it was mostly useless. granted, the feet were much bigger in 07 but getting hung up after hanging may be an issue to be aware of.
otherwise, good work... your team likes to make a lot of videos i see...
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 02-02-2011, 23:03
How much have you played with the geometry of the gripper fingers and the extension length? From the only two I got to see from 07, 25's had a really solid grip on the tubes with what seemed like only two direct contact points. Ours OTOH had the fingers wrap around the tubes. There might be some type of uniform design that'll work for all 3 tubes.
With tube
No tube
Open gripper
In action!
Hope it helps with more ideas for the gripper!
Good luck ya NERDS
Unread 02-02-2011, 23:10
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Right you are!
...and very well I might add.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 02-02-2011, 23:26
Chris is me's Avatar
AKA: Pinecone
Interesting prototype!
Looks like 1726 and 2791's bots will look VERY similar this year... but that inside gripper is definitely a different direction than we took. We liked how both pinch claws and roller claws could just "drive into" a tube to grab, while the inside gripper would need to be carefully placed inside a tube to grab.
Have you guys done any prototyping with regards speed of grab? If it turns out we're dead wrong it's not too late to change direction!
Unread 02-02-2011, 23:39
AKA: Carl Springli
Rookie Year: 2010
We have, turns out if you can drive with the grabber just above the tube and then bring it down and expand it you can get a good grip in less than 2 seconds. Of course you can also lower it into the center of the tube and then start driving away as you expand it and then its down to about a second. It was also a lot easier to align than anticipated when we mounted the grabber to an old 6 wheel WCD bot, which could be made even easier with a swerve drive...
That being said, I think in the end it'll come down more to execution of design rather than which direction you took. Since you already have many iterations of the pinch claw/roller claw concepts, statistically speaking you are more likely to execute a pinch/roller claw well than to execute an inside expander well. So in this case it seems like there are no 'right' or 'wrong' directions, just ones that you are more or less familiar with.
Unread 02-02-2011, 23:48
AKA: Pinecone
My concern is having to consciously go "okay, we're next to a tube, stop, lower, grab, up" rather than juts driving forward and havign the tube slide along with your arm.
I highly doubt we'll adapt the design but I'd love to see it implemented successfully.
Unread 02-02-2011, 23:51
AKA: Carl Springli
Rookie Year: 2010
Well then you would love to see this!
http://www.thebluealliance.net/tbatv/match/2007ct_qm52
Unread 02-02-2011, 23:58
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Why even bother gripping, when you can take elevator a bit more literaly...
Our gripper travels on an elevator similar to the one in the OP, but it has two sides, for extra support!
Unread 02-02-2011, 23:59
MrForbes's Avatar
AKA: Jim
Chris, the idea is that we drive into the tube, scoot it along the floor, and drop the claw into it and pop it open and lift the arm. The pointed claw when it's "retracted" is a small triangle fitting into a big hole, so aim is not very critical at all.
Unread 03-02-2011, 06:39
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
We are doing the same thing. We designed our inside gripper (prototype here) to move down to the "grip" position so that is was inside all three shapes. No slowing down is necessary. Drive up to it, Push it and pick up.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 03-02-2011, 09:04
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Nice video
This is exactly how I was imagining the pick up going. If it works right, all you need to do is drop the arm down, then you can open the claw and raise the arm on the way to the goal, drastically lowering the amount of work required to take control of the tube. In fact, that just makes one motion necessary, which puts the inside grab on par with a normal pinch type claw.
  #15   Spotlight this post!
Unread 03-02-2011, 09:11
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
A few things to keep in mind this year:
1. in 2007 you could shape your bumpers to help position the tubes.
2. The target holes are smaller than they were in 2007
3. In order for you to get the most out of your robot, you have to make sure your drivers have enough time to get proficient with the pick-up.practice, practice, practice!
