Go to Post The battery will be mounted at the top, correct? There can be no other way. - Travis Hoffman [more]
Unread 03-02-2011, 15:41
MechanicMaster MechanicMaster is offline
FRC #2876
MechanicMaster is an unknown quantity at this point
Spike Breaker
how is the spike breaker used in the pneumatic system?
does it regulate the solenoid?
Unread 03-02-2011, 15:45
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Spike Breaker
The breaker/fuse in a spike relay protects the circuit from drawing too much current. Typically, pneumatic devices are a very low-demand application as far as electric current, but in the case of a short or similar malfunction, the breaker will shut the circuit down.
The spike itself is wired to the digital sidecar, and used to turn a solenoid on or off, if you do not have any ports available in the pneumatics breakout.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 03-02-2011, 16:09
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Re: Spike Breaker
If you are using Labview, take a look at the Compressor VI in the examples. It shows you how to wire AND program the pneumatic system.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 03-02-2011, 16:16
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Spike Breaker
Mechanic,
A spike is needed to turn the compressor on and off. This is used with the compressor VI in Labview by reading the pressure switch and turning the Spike on. Spikes can also be used to control pneumatic solenoids but the solenoid module for the Crio is easier to implement from a wiring standpoint.
As a reminder, if you use the Spike for controlling a compressor, you should replace the 20 amp fuse in that Spike with a 20 amp circuit breaker.
Al
WB9UVJ
www.wildstang.org
________________________
