Go to Post Brandon, can you make some sort of mind-reading device that i can just think "portal" and i'll go back? - Tom Schindler [more]
Unread 03-02-2011, 15:53
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Exclamation Potentiometer code
I was wondering if anyone can tell me if this code works.
v
Uploaded with ImageShack.us
Unread 03-02-2011, 15:56
FRC #2905
Re: Potentiometer code
Victors are connected to window motors.
And window motors controls the arm.
Angle(min) = 30 degrees.
Angle(max) = 120 degrees.
Unread 03-02-2011, 18:09
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
It won't work, although your angles are calculated correctly.
The setpoint input (the desired position) must be is the same units as the process variable (the current position).
The potentiometer is in volts: 0-5v
You can either convert the pot voltage to match your angle range, or change your angles to be the pot voltage range.
The pot voltage min/max range will have to be measured by moving the arm to it's minimum/maximum position and reading the pot value through the LabVIEW front panel or a LV probe.
Unread 04-02-2011, 03:31
FRC #2905
Thumbs up Re: Potentiometer code
Thank you really much Mark !!!!
Unread 04-02-2011, 08:29
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by Mark McLeod View Post
]The pot voltage min/max range will have to be measured by moving the arm to it's minimum/maximum position and reading the pot value through the LabVIEW front panel or a LV probe.
Or you could just measure it with a voltmeter.
Unread 04-02-2011, 10:05
Just Itinerant
That's the answer in the Electrical sub-forum.
LabVIEW means we don't need multi-meters.
Unread 04-02-2011, 10:42
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
I attached a VI I wrote to handle scaling of analog inputs, it assumes your Potentiometer has a linear taper (some have log tapers) Min and Max voltage are the voltages at the min and max angles, not necessarially 0v and 5v
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
