Go to Post Oh... and congratulations FIRST, for launching the biggest shinny object of distraction just days before FRC kick-off. ;) - Michael Sperber [more]
Unread 03-02-2011, 18:56
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
Smile How to program an arm?
I have the 3 servo motors for the arm programmed in the begin vi, I have The second joystick programmed in the teleop vi, and the begin vi , now what.
Unread 03-02-2011, 19:03
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Re: How to program an arm?
Well you need to decide how you want to control your arm
1.buttons?
2.joystick?
3.telekinesis?
You need to give us some details so we can help you the best
Expect the best, Prepare for the worst
Unread 03-02-2011, 19:08
well it will have 3 degrees of freedom so 3 motors, (telekinisis would be nice ) but one motor with the x axis, and the other 2 with 2 buttons each.
Unread 03-02-2011, 19:13
We already have the arcade drive with the first joystick for the driving part programmed good, we just need the arm. I even have the 2nd joystick programmed into the teleop vi, i just need to know how to program the buttons and x axis to joystick.
Unread 03-02-2011, 19:31
AKA: Jon
1-ok, well First you are going to want to pull out the reference for your second joystick
2-Second you need to pull down a Get.vi
3-Third you need to get two unbundle by name functions from the Cluster,Class and Varient section
4-Wire the unbundles to the button and axis output
5-you need to create open.vi's for three motors (each one set to its pwm)
6-To make the motors move on a button you are going to need a case structure for each motor with the set speed.vi in the case structure set to the speed you want to move it
6-for the axis just wire axis one into a set speed.vi
If you are needing to learn the basics i suggest you watch the videos from here http://www.frcmastery.com/
Unread 04-02-2011, 17:07
and this is all in the teleop vi?
Unread 04-02-2011, 17:10
AKA: Jon
Yes, sorry i would post a pic but snowed in without a programming computer
Unread 04-02-2011, 17:13
np. by the way, how is your season going?
Unread 04-02-2011, 17:17
and on step 6 i am confused, the other 5 i already got.
Unread 04-02-2011, 22:13
AKA: Jon
to get a motor to turn at a certain speed when using a button you put a motor set speed.vi in the true case of the case structure,then wire the unbundled button to the case condition. The false case needs to be a set speed.VI set to what you want the motor to do when the button isnt pressed
Unread 05-02-2011, 10:25
wait, so i have step 2 in the 7 steps thing, now what?
