Go to Post Ah, this sounds like a sitcom whose pilot I should write and send to NBC - "Life With Lavery". There's a lot of eating, several practical jokes, and lots of bad hair. - Amanda Morrison [more]
Unread 03-02-2011, 22:46
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Question New driver station problem
Has anyone else had any problems with the updated driver-station loading their dashboards?
I just got mine updated to this year's version, and now the dashboard wont load with the DS. I know you have to edit the .ini file under the FRC folder in All User's documents... but after I change the command line to the one that needs to be used something happens to change the file when I run the DS.
For instance if I use the command line: ""C:\Documents and Settings\Administrator\My Documents\LabVIEW Data\FRC Dashboard\FRC Dashboard.exe""
The line gets changed to something like:""C:\00cuments and Settings\0ministrator\00ocuments\LabVIEW Data\0FC Dashboard\0FC Dashboard.exe""
Does anyone have any ideas on how to fix this? and has anyone else had this problem?
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 03-02-2011, 23:20
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: New driver station problem
You need double slashes in the filename path, e.g.,
""C:\\Documents and Settings\\Administrator\\My Documents\\LabVIEW Data\\FRC Dashboard\\FRC Dashboard.exe""
Unread 03-02-2011, 23:23
randalcr's Avatar
Programming Mentor
AKA: Chance Randall
ah, ok. Thanks Mark!!
