Go to Post Representing data in a good way is an art in its own right. - Andrew Schreiber [more]
Unread 05-02-2011, 06:30
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Update!
Originally Posted by Ether View Post
That is a bit unsettling.
Sorry about the release date not being changed. We'll fix that. This is a required update that you need.
Doug Norman
Unread 05-02-2011, 09:22
Joseph W. Horth Joseph W. Horth is offline
FRC #0280
Joseph W. Horth is an unknown quantity at this point
Re: Update!
The updated labVIEW File caused my labVIEW to not work anymore. When I open it up and hit launch it says unable to open resource files and then closes.
What happened and how do I fix it?
Unread 05-02-2011, 10:14
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Update!
I did the install on 2 laptops.....LV comes up on one, not the other. The same error! 'Unable to open resource files'
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 05-02-2011, 12:55
Re: Update!
I updated my copy on the one laptop I have with me and it worked -- meaning I have little to debug with.
John, can you compare the procedure on the two laptops? Do you think it was a difference in the laptop or in the install steps?
Can you easily compare the results? Inside Program Files/National Instruments/LabVIEW 8.6/resource, there should be 95 items according to my installation. Do you see something obviously wrong?
Thanks in advance.
Greg McKaskle
Unread 05-02-2011, 13:21
Jon236's Avatar
AKA: Jon Mittelman
Rookie Year: 2000
Re: Update!
I copied the entire resource subdirectory over to the afflicted laptop and got a Win7 "Program Has stopped working" with the following details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: LabVIEW.exe
Application Version: 8.6.0.4002
Application Timestamp: 4cb70867
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7600.16385
Fault Module Timestamp: 4a5bdbdf
Exception Code: c06d007e
Exception Offset: 0000b727
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1033
Additional Information 1: cba5
Additional Information 2: cba57985d4dfc600ca12eaab7140e875
Additional Information 3: 7cb7
Additional Information 4: 7cb7f00025d289dc6d0ac96eb597182c
Jon Mittelman
Unread 06-02-2011, 10:17
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
Re: Update!
Do we need to reinstall the Utilities update after the 3.1 LV update?
Unread 06-02-2011, 10:41
Re: Update!
I do not believe so. I simply did the update and my machine seems fine. I can use the wizard to build a new sample, and I see the new examples that were added. I don't have a cRIO at home, so I can't test that part.
I believe the utilities is mostly the vision tools.
Greg McKaskle
Unread 06-02-2011, 14:03
Jon236's Avatar
AKA: Jon Mittelman
Rookie Year: 2000
Re: Update!
I solved our problem with a complete NI uninstall, followed by reinstalling everything! Worked fine! (whew!)
Jon Mittelman
