Go to Post If I understand what you're saying, you don't understand very far. - Alan Anderson [more]
Unread 04-02-2011, 12:27
RcDawson RcDawson is offline
FRC #2972
RcDawson has a spectacular aura aboutRcDawson has a spectacular aura about
Replacement for Locking Pin (Window Motors)
We went through and removed the locking pins from the Denso window motors, but due to the small nature of them, we lost them. When testing the arm, we found that without the pins, the arm did not support itself and gravity was able to pull it down. Is there any way to make a replacement for these locking pins out of a similar material? Or any solution we could use to not have gravity overpower the motor?
