Go to Post Only Dave knows [if the 2010 game is designed already], and he aint tellin' but he'll happily feed you lots of red herrings. - Koko Ed [more]
Unread 04-02-2011, 13:12
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
FRC #0461 (Westside Boiler Invasion)
Team Role: CAD
Rookie Year: 2010
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Help with CNC router
Hi, I'm Brian French, I'm the person responsible for operating the CNC router for 461. Our router has been having an interesting problem where it loses it's zero settings, both the machine zero at the bottom left corner and the program defined zero at the corner of the piece. It only does this intermittently, so we can make parts, but it takes more tries than it should. The zero always shifts to the left, but the direction in the Y and Z are random; it's cut 3/4 inches into the machine bed, but it's also missed the part by nearly an inch above.
Just for reference, the toolpaths are generated by using the sheet metal function of Autodesk Inventor 2011. The files are then converted to a .dwf using the shop drawing feature. From there the .dwg is moved over to the CNC control computer, where V-Carve 6.0 generates the toolpaths that get executed on the CNC via Mach 3 CNC controller.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 04-02-2011, 13:16
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: Help with CNC router
is it an open loop stepper motor system, or a closed loop encoder system?
Unread 04-02-2011, 13:17
iScout
Team Role: CAD
Rookie Year: 2010
open loop, there are no encoders for it to take feedback from
Unread 04-02-2011, 13:50
AKA: Ty
well if its losing zero gradually while cutting it.
is probably the stepper motor losing count. that's caused by tolerance in the drive mechanism and backlash transmitted through the cutting tool. sharp well maintained tools designed for the material you are cutting are a must for such machines. my best suggestion to fix the inaccuracy it accumulates without too much work is to adjust and tighten all bearings, lead screws and nuts. put some clamping pressure on the machines tracks to take out some of the machine play and vibration. and make shure the whole system is well lubricated. also low quality terminations on the power wires and frays in the motor wires can cause intermittent loss of motor power and therefore loss of zero. i am cuttently in the process of converting my stepper motor 3-axis mill to ball screws because of these problems .also if you are having troubble losing count you can try adjusting the amperage to the motors. increasing it will make them hold position better, and you can also try changing between full step 1/4 1/8 and 1/2 steps if your board has that capability. single step has the most electromangets on at the same time for best holding and the fraction steps have higher resolution but less electromagnets activated simultaneously so less holding force
Unread 04-02-2011, 15:18
DonRotolo's Avatar
Back to humble
FRC #0832
...and if it is losing zero instantly some time during run, then it is likely a bad connection, electrical interference, or (depending on how zero is set) something accidentally resetting the zero. Soyy, I'm not familiar with V-Carve
Unplug and reconnect every connector and terminal, regardless of where.
has the machine been moved recently, or any new machines (or anything electrical/electronic) in the area? Like a welder?
When you run it, are any other machines in the shop in use?
Unread 04-02-2011, 15:50
iScout
Team Role: CAD
Rookie Year: 2010
I opened the case up and everything was alright, so I doubt that that is the problem. However interference could be a possibility, so I'll check that.
Unread 04-02-2011, 15:56
DonRotolo's Avatar
Back to humble
FRC #0832
Honest. Unplug and reconnect everything. Unless you find the issue elsewhere, of course.
And if you do, tell us!
Unread 04-02-2011, 17:15
paly paly is offline
VRC #0008
paly is an unknown quantity at this point
Our CNC loses it's zero when our welder, which is stationed about 5 feet away from there, turns on. Interference by a welder or any other heavy tools is definitely possible.
Unread 04-02-2011, 18:45
gren737 gren737 is offline
AKA: Sarah Grenier Montplaisir
Rookie Year: 1995
gren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond reputegren737 has a reputation beyond repute
Everyone here is on the right path, it is interference. Find out what circuit you are plugged into and make sure you don't run anything else on that circuit.
I used to design CNC machines and I had one that kept drifting during a test and randomly losing it's 0. Couldn't figure it out for the life of me. Took it apart several times, changed all the motors, changed out wires....
Some one else was making parts on a machine a few minutes away and kept using a shop vac to clean up the chips...culprit found.
The shop vac was plugged into the same circuit.
Good luck!
Unread 04-02-2011, 19:00
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Help with CNC router
Just a thought, but what kind of material are you cutting, and at what feed rate? A sharp cutter would also help with an open loop system.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 04-02-2011, 22:15
iScout
Team Role: CAD
Rookie Year: 2010
We found the problem, when it cuts to screensaver it rezeroed the path. We disabled the screensaver and we're good to go.
Unread 05-02-2011, 14:42
AKA: Ty
Windows Fail
Unread 05-02-2011, 17:16
DonRotolo's Avatar
Back to humble
FRC #0832
Thanks, good learning experience for us all.
Unread 05-02-2011, 19:12
iScout
Team Role: CAD
Rookie Year: 2010
Windows Fail
you know it
