Go to Post You know those gravitational waves you keep hearing about recently? Those weren't created by colliding black holes, they were created by our boulders colliding with the opposing alliance's tower. - JohnFogarty [more]
Unread 04-02-2011, 16:28
RoboElite640 RoboElite640 is offline
FRC #0640
RoboElite640 is an unknown quantity at this point
Help needed for loading codes into cRIO (Java)
Error comes up while downloading java codes into cRIO. I installed the FRC plugins. Formatted the cRIO and reimaged it. Firewall is also turned off and the IP address is set to 10.6.40.5
C:\Documents and Settings\Developer\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line:
C:\Documents and Settings\Developer\sunspotfrcsdk\ant\upgrade.xml:4 0:
java.net.ConnectExtension:Connection timed out: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl .java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSoc ketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.j ava:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.j ava:366)
at java.net.Socket.connect(Socket.java:529)
at java.net.Socket.connect(Socket.java:478)
at java.net.Socket.<init>(Socket.java:375)
at java.net.Socket.<init>(Socket.java:189)
at org.apache.commons.net.DefaultSocketFactory.create Socket(DefaultSocketFactory.java:53)
at org.apache.commons.net.SocketClient.connect(Socket Client.java:162)
at org.apache.commons.net.SocketClient.connect(Socket Client.java:250)
at com.sun.spot.sdk.tool.ftp.JakartaFtpWrapper.connec tAndLogin(JakartaFtpWrapper.java:37)
at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(Upgr adeTask.java:213)
at org.apache.tools.ant.UnknownElement.execute(Unknow nElement.java:291)
at sun.reflect.GeneratedMethodAccessor74.invoke(Unkno wn Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.tools.ant.dispatch.DispatchUtils.execut e(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:39 0)
at org.apache.tools.ant.Target.performTasks(Target.ja va:411)
at org.apache.tools.ant.Project.executeSortedTargets( Project.java:1397)
at org.apache.tools.ant.helper.SingleCheckExecutor.ex ecuteTargets(SingleCheckExecutor.java:38)
at org.apache.tools.ant.Project.executeTargets(Projec t.java:1249)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java :442)
at org.apache.tools.ant.taskdefs.CallTarget.execute(C allTarget.java:105)
at sun.reflect.GeneratedMethodAccessor149.invoke(Unkn own Source)
at org.apache.tools.ant.Project.executeTarget(Project .java:1366)
at org.apache.tools.ant.helper.DefaultExecutor.execut eTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.module.bridge.impl.BridgeImpl .run(BridgeImpl.java:281)
at org.apache.tools.ant.module.run.TargetExecutor.run (TargetExecutor.java:539)
at org.netbeans.core.execution.RunClassThread.run(Run ClassThread.java:154)
Build Failed (total time:59 seconds)
HELP NEEDED
Unread 05-02-2011, 07:58
FRC #0640
Re: Help needed for loading codes into cRIO (Java)
bump
Unread 05-02-2011, 08:27
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
First off, no bumping threads.
Can you ping the cRIO from the Classmate (or whatever computer you're using to load code)? Is the ethernet cable a crossover (I've heard straight-throughs can be used, but FIRST recommends a crossover). Is the cable actually plugged in (i.e. not slipping out of anything)?
Unread 05-02-2011, 14:04
FRC #0640
sorry, didnt know about the no bumping. Being new, im not sure what you mean by ping. We're using a straight cable and its plugged in (not loose).
Unread 05-02-2011, 21:25
1168Programmer 1168Programmer is offline
Head Programmer/CEO
FRC #1168
Team Role: Student
1168Programmer is an unknown quantity at this point
To ping, go to command prompt, (for windows, if you see "run" on the start menu, click that and select cmd [or type it], a black window should pop up), type "ping" and the ip address of your crio. It will send data packets to your crio, if they are sent back then you are connected and the problem is something else.
Unread 06-02-2011, 16:44
FRC #0640
Well we can't try to ping it until Monday, but if it doesn't ping then what should we do?
Unread 06-02-2011, 17:07
Head Programmer/CEO
FRC #1168
Team Role: Student
Try to deploy tethered, if you're not doing that already.
In your original post it says an error occurred at a certain line, I think it says line 95. So, maybe check that.
Hmm, do you have the most recent plugin update?
Is there anything in your code that would cause the connection to just time out?
Unread 06-02-2011, 17:36
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
Rookie Year: 2011
inkspell4 will become famous soon enough
You will have to have it connected to the wireless and then make sure that the dric=ver station is deployed then build if this doesnt work follow the instructions on http://www.usfirst.org/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2011_Assets/Kit_of_Parts/How_to_Build_and_Load_Programming_in_LabVIEW,_C,_a nd_Java.pdf this is supplied by first if on monday the problem still exists i will speek with one of my fellow programers. We are also a new team so we understand this situation.
Chesapeake Regional : 2013, 2012, 2011
Rookie Year: 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 06-02-2011, 19:48
FRC #0640
We do have the most recent plugins for java. I dont think theres anything that would cause the connection to be timed out because i tried using simple codes and it still said connection timed out. I'll try wireless tomorrow but if the connection is interrupted then wont the cRIO be corrupted or is that only when you reimage it?
Unread 06-02-2011, 19:52
Head Programmer/CEO
FRC #1168
Team Role: Student
Did you reimage it to the right programming language?
Definitely try pinging it and let us know what happens.
Unread 07-02-2011, 08:59
FRC #0640
I tried pinging it and i got 4 packages sent and 4 packages received. I also tried using a crossover cable and still got the same error. I have the cRIO IP address at 10.6.40.2, but what exactly should the subnet be at 255.0.0.0?
Unread 07-02-2011, 12:12
adf0221 adf0221 is offline
FRC #1517 (Lumberjacks)
Rookie Year: 2011
adf0221 is an unknown quantity at this point
make sure you disconnect from the radio on your robot before you attempt to download or else you will receive that error
