turning a push button into a switch
I am trying to get the robot to switch a state based off the single press of a joystick button. I designed a system that i thought would work, but it began constantly switching the state back and forth without me pressing anything every (what I believe based off how i designed it) 10 ms.
I don't have the code with my right now, but in pseudo code this is what i did. In periodic Tasks |
I don't have the code with my right now, but in pseudo code this is what i did. Code:
In periodic Tasks.vi
10 ms loop
If button pressed
if global button data == true
set global button data = false
if global button data == false
set global button data = true
In Teleop.vi
If global button data == true
set solenoid = forward
else
set solenoid = reverse
If anyone can tell me why it did what it did, how to fix it, or another approach altogether, I would very much appreciate it. I will post the real code ASAP. |
Re: turning a push button into a switch
I attached the code we made this year. To use it, just put it in a vi, connect up your momentary button and "switched" output, and then make a shift register and wire that up to the top. The shift register is outside the vi so we can use the same vi many times (if it were inside, the shift register would maintain its values from call to call, not just from loop to loop.)
The problem with your program is that if you press the button for more than 10 ms, it will change twice. My program waits until the button then gets unpressed before going back to the "ready to receive button" state. I have no idea why your code would switch when you're not pressing the button if that's the actual way you coded it. My vi works fine in teleop; there's a 20ms loop in teleop and your code has a 10ms loop; it's not a big difference. The 20ms actually helps debounce the switch for us. NOTE: This code is untested in the real world - you might have to do something to debounce switches. I did test it in the vi with the front panel controls though. EDIT: Added bundle/unbundle to code to have only one shift register. Last edited by WizenedEE : 04-02-2011 at 23:34. |
Here's how my team does it: http://forums.usfirst.org/showthread.php?t=10544 |
I guess labview can run the robot without motors. |
Oh yeah, you can simulate the entire system without even connecting to the cRIO if you know what your doing. I rarely get the robot until the last minute, so I'm usually simulating everything, though my simulation didn't pick up the constant solenoid changing. Anyway, thanks for the help everyone. will test it out tomorrow. |
Looks like you accidentally made two topics...
http://www.chiefdelphi.com/forums/sh...ad.php?t=90955 |
We are still working on our code. Thanks for all the advice. We will post code this week. Thanks again for all the help. |
#10
Based on your pseudo-code, I'm not sure why it would be toggling without anything pressed. However, it will definitely toggle every 10 ms when the button is pressed.
What you need to do is to save the state of the button in the previous loop and compare it to the value in the current loop and only do something when it changes. You can save old values using feedback nodes or shift registers. Take a look at the "button action" examples from http://team358.org/files/programming...2009-/LabVIEW/ |
#11
Take a look at this:
http://zone.ni.com/reference/en-XX/h...feedback_node/ When you wire something into a feedback node, it's previous value comes out. If its previous value is false, and its current value is true, then it was just pressed and you can change states. This ensures it will only change states once per press. I attached an example of this here. |
#12
The attached code does work, but may I suggest replacing the negate and AND with a notEqual node? In Boolean algebra, they are equivalent, but if this were a number or string, Boolean doesn't work any longer. I also think the verbal description is probably more understandable to others.
Greg McKaskle |
#13
Good catch. That is why it is better to actually write and run code and not just talk about it.
Greg McKaskle |
#15
Greater-than and less-than are perfectly happy with boolean values. My favorite idiom for detecting the moment of a button press is to use a feedback node and a greater-than. Using a less-than instead will detect the button release.
