Go to Post FIRST is like riding a bike. At first it may seem hard and confusing, but after a few tries you get the hang of it and its smooth sailing from then on out. - Tom Bottiglieri [more]
Unread 04-02-2011, 23:39
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
Rookie Year: 2010
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
LabView Deploy
I was wondering how to deploy code in LabView. The document on the KOP website says to just hit the run arrow, is it really that simple or do I have to click a "deploy" button?
Unread 04-02-2011, 23:48
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
Re: LabView Deploy
Hitting the arrow in robot main will deploy the code, assuming you have your driver station and robot all connected to the network. Clicking the finish button or the abort button (not recommended) in robot main will un-deploy the code.
If you want to make the robot run without a second laptop (just the driver station/classmate PC), you have to go to the project explorer, open up the RT CompactRIO Target section, then the Build Specificiations section, then right click on FRC Robot Boot0up Deployment and select build, wait for it to finish, then right click on it again and select run at startup. Note that this is ONLY if you don't want to use your programming laptop to run the robot (like at competition, or if you use your classmate to program).
Note that if you do the second option, you can't see debug data with things like probes. You must send any debug data you want to have to the dashboard (which is annoying).
