Line sensor spacing
How far apart do the three line sensors need to be spaced? Also, which two wires, and which direction are they supposed to be plugged into the digital I/O of the digital sidecar?
Re: Line sensor spacing
I'm not sure about the spacing, but I know there's a knob to zoom in and out. I plan on using 1.5" spacing for now.
The brown wire is your plus, the blue wire is your minus. Those go into the power panel. A pull-up (6.4K if i'm remembering correctly) resistor bridges the power and signal ports on the digital side car and the white wire connects to the signal port as well. (See attached) The black wire can be covered up with a piece of electrical tape, so It doesn't blow the whole sensor if it touches something accidentally. Since I'm doing this all from memory, I'm not liable if you blow something. Last edited by cgmv123 : 05-02-2011 at 09:46. Reason: legal disclaimer |
Is that resistor something that you found and put on, or is it already there, or did it come in the KoP? Where did it come from?
Check out this thread for wiring. http://www.chiefdelphi.com/forums/sh...threadid=88548
It sounds like because of how the Digital Side car is engineered it should not need a resistor. - Don't quote me on this. |
The control board has a resistor in it already.
implosionprez, we had the resistor lying around. They're cheap and you can get them at any hardware store.
Peyton, it didn't work without the resistor and it did with it. Read that however you want. |
Under normal circumstances, you can connect the dark output (DO) or light output (LO) of the light sensor directly to your input on the sidecar. Matt |
1.5" is to close. we found this out by programming them.
theschell, we actually ended up going even closer. There's a zoom knob you can use to adjust the depth of field.
#10
cgmv123, we are trying to get our followers to follow our line. So far we follow and our teleop mode doesn't switch. We dont know what is wrong.
#11
If you're following OK, that's not something with the sensors then.
