Go to Post If this was really about changing the culture, FIRST would be on Will.I.Am's website. - Meredith Novak [more]
Unread 05-02-2011, 10:52
siggy2xc siggy2xc is offline
AKA: Tyler Siegrist
FRC #1756 (Argos)
siggy2xc is an unknown quantity at this point
Read pre-determined set of numbers
I would like to be able to write a pre-determined set of numbers as a joystick input over time. how would i go about doing this?
Unread 05-02-2011, 11:04
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: Read pre-determined set of numbers
I would store them in an array and then index into different elements of the array using the elapsed time.
You can see an example of how to do this in the default Autonomous code. The motor powers are stored in an array ("Straight Power" and "Y Power") and then elapsed time in seconds is used as an index.
