Minibot
Once the minibot is deployed can it exceed 12X12X12?
We couldn't find this in the rules but are wondering if we can have the minibot get bigger |
Re: Minibot
As per the Q/A, Minibots may not exceed the 12" cube at any time.
http://forums.usfirst.org/showthread.php?t=16522 <G41> MINIBOTS may not exceed a 12” x 12” x 12” volume. <R91> The MINIBOT may not exceed a 12” x 12” x 12” volume and weigh no more than 15 lbs. |
How big is the pole in diameter that the minibot needs to climb?
Re: Minibot
Re: Minibot
A mentor of ours is suggesting that we should not use heat shrink for any non-electrical (say, mechanical hold down, for example) use on the minibot despite there being no qualification of that sort in the list of approved materials. He is going by what FIRST rules on the main robot in general. What do you think? Is there a definitive statement on this somewhere that I've missed?
Re: Minibot
Re: Minibot
Re: Minibot
I was wondering whether or not to we can use steel tubing in our minibot to attach our magnets to, as the sec 4 P30 <R92> this dealing with permissible materials on bullet H. it lists, "Raw welding rod, aluminum sheet, 90° angle, u-channel, tube, bar, that is not sold pre-perforated/pre-punched." It is vague and we think we can but confirmation would be nice.
Re: Minibot
I think you answered your own question. You said steel, the rule said aluminum. No go.
EDIT:You could, however, use a piece of Tetrix C-channel(I believe it's steel.) Last edited by rutzman : 22-02-2011 at 20:47. Reason: Thought of alternative solution. |
#10
Re: Minibot
<R92-H> deals with aluminum. This was much clearer in the earlier revisions of the Manual, which read, after TU#4, "<R92-H> Raw aluminum sheet, 90° angle, u-channel, tube, bar, that is not sold in pre-perforated or pre-punched form." (Also note the revision log, which notes that Revision D had a revision to clarify raw aluminum usage.) The placement of the "Welding rod" addition (Rev. G) may have thrown you off a bit.
In other words, nope, find some other way of attaching your magnets. EDIT: I'm a little bit surprised at whoever does the Updates and associated Manual revisions right now. The current rule, from Rev. K, reads: Quote:
