Go to Post We always cut our parts to a tolerance of /- the width of that particular sharpie mark. - Whippet [more]
Unread 05-02-2011, 11:28
terry-kuhn's Avatar
terry-kuhn terry-kuhn is offline
sad
AKA: Terry Wen
FRC #2403 (Team Plasma)
Rookie Year: 2010
terry-kuhn is an unknown quantity at this point
Converting 32-bit image to 8-bit OR binary
How can we use the vision assistant to convert 32-bit webcam images into a format that the image processor can compute?
Unread 05-02-2011, 12:02
Re: Converting 32-bit image to 8-bit OR binary
NIVision contains functions to extract a color plane and to threshold. Those are the two most common ways to take a color image and ready it for monochrome processing.
If you are wanting to identify colored objects in the image, look at using the color threshold as the first step of processing, either in your vision assistant code or in the code between the camera and the assistant code.
Sometimes, you will instead extract the lunimance or saturation plane.
Greg McKaskle
Unread 05-02-2011, 12:13
terry-kuhn's Avatar
sad
AKA: Terry Wen
Rookie Year: 2010
THANKS!!!
