Go to Post Never be afraid to admit your ignorance, and ask someone something. You may just learn something new... - kmcclary [more]
Unread 05-02-2011, 14:24
CaptainKemp CaptainKemp is offline
AKA: Morton
FRC #0888 (Robotiators)
CaptainKemp is an unknown quantity at this point
Red Blinking Light on Jaguar
Hello,
I know I there are a couple other threads on here about the red flashing light on a jaguar but none of them helped me know where to check for the problem. I saw something about undervoltage and I checked the wires and it was 12.09 V.
The Jaguar works in one direction but when I tell it to go the other direction, the lights starts to go the right direction but then turns into a slow blinking red light. I know this isn't a good thing but I don't know how to fix it.
Can anyone please help me?
Thanks,
Morton
Team 888
"Any sufficiently advanced technology is indistinguishable from magic." - Clarke
Unread 05-02-2011, 14:58
travis.calhoun's Avatar
travis.calhoun travis.calhoun is offline
3778
FRC #3778 (Texsquad)
Team Role: Electrical
Rookie Year: 2011
travis.calhoun is an unknown quantity at this point
Re: Red Blinking Light on Jaguar
Doesn't the red light on the Jaguar indicate the polarity of the motor is negative, thus it is in reverse?
EDIT: Nevermind, you said SLOW blinking red light. Yeah, it's a fault condition. Sorry bro
Unread 05-02-2011, 20:14
plnyyanks's Avatar
plnyyanks plnyyanks is offline
Data wins arguments.
AKA: Phil Lopreiato
FRC #1124 (The ÜberBots), FRC #2900 (The Mighty Penguins)
Rookie Year: 2010
plnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond reputeplnyyanks has a reputation beyond repute
Are you using black or grey jags? Last year, when using grey ones, when we would try to abruptly change directions, the jaguar would overcurrent and go into a fault condition. After a little while does the jaguar reset and go back to working?
We fixed this by putting a limit on how fast the robot could accelerate in code. It worked (or you could switch to black jaguars, which didn't do this)
Phil Lopreiato - "It's a hardware problem"
Team 1124 (2010 - 2013), Team 1418 (2014), Team 2900 (2016)
FRC Notebook The Blue Alliance for Android
Unread 05-02-2011, 20:24
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
That sounds like the "limit switch" feature.
Check your limit switch jumpers. They are the two vertical jumpers on the far right, shown in the image below:
(This Jaguar has been marked up for better visibility)
-- Marshal Horn
Unread 05-02-2011, 23:02
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
We had the same problem with one of our gray jags, and someone else on CD has it also. We ended up just declaring it dead (maybe use it sometime for a unidirectional motor).
Oh yeah, ours started smelling bad after a while of running it backwards.
Unread 06-02-2011, 12:37
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Sounds like you got some metal shards in there.
-- Marshal Horn
Unread 06-02-2011, 12:45
LV1601's Avatar
LV1601 LV1601 is offline
FRC #1601
LV1601 is an unknown quantity at this point
Well to my knowledge red flashing is either slow reverse or an overworked motor. I found that out the hard way. It might be the limit switch or check the motor to see if it is not jamming and any point.
Unread 06-02-2011, 12:51
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Morton,
It is possible that you have mechanical issue. It runs fine in one direction and then binds in the other. Are you driving one of the window motors with this controller? The window motors have locking pins that could prevent movement, particularly if you are driving two motors on a common shaft.
Al
WB9UVJ
www.wildstang.org
________________________
