Go to Post Aw... am I too late to suggest a water game? - jgannon [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 05-02-2011, 15:32
duffany1 duffany1 is offline
AKA: Brandon
FRC #0195 (The Cyberknights)
duffany1 is an unknown quantity at this point
How to Mount a Gyro
Okay... So we understand how the gyro works but we are having trouble figuring out where to mount it and how to mount it. If anyone can provide a detailed description and pictures possibly that would be wonderful. Thanks in advance!
Unread 05-02-2011, 16:47
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Talking Re: How to Mount a Gyro
If you are trying to measure the angle of the robot you are going to want to mount it closest to the middle of the robot on a platform that insulates the gyro from anything else (ex. wood,rubber,etc)
Last year we put it in a wood box and mounted the box to the frame.
Expect the best, Prepare for the worst
Unread 05-02-2011, 17:07
DonRotolo's Avatar
Back to humble
FRC #0832
Mount it firmly to the robot - some vibration is OK but letting it move relative to the chassis is bad. As above mentioned, the center of the chassis base is a good idea, down low is good.
We have used velcro to good effect, allowing for easy mounting and removel when necessary. We have also used small non-metal screws (there are mounting holes) and even zip ties successfully. On a practice bot, we held it down with duct tape.
Unread 10-02-2011, 00:26
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
Why does it matter how close to the center of the robot they are? I've been trying to figure that one out for a while.
Unread 10-02-2011, 11:14
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Think about an extreme example where the gyro very far from the axis of rotation. Its a yaw rate sensor where the amount of rotation is determined by integrating the angular acceleration. You can indirectly compensate for the increased acceleration by changing your mv/deg/s constant, but you will reduce the maximum deg/sec you can measure before you out pace its ability to keep up.
Unread 10-02-2011, 14:37
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The datasheet for the ADXRS150 says the null has a linear acceleration effect of 0.2 degrees per second per g.
So if the gyro were mounted, say, 38/2 = 19 inches away from the center of rotation of the robot, and the robot were rotating at 180 degrees per second, you could calculate the effect:
180 degrees/sec = 3.14 radians/sec
(3.14^2)*(19) = 187.5 inches/sec^2 = 15.6 ft/sec^2 = 0.488 g's radial acceleration
So (0.2 degrees/sec/g)*(0.488 g) ~= 0.1 deg/sec
Unread 10-02-2011, 16:22
AKA: Jim O'Malley
Ouch! I had never really considdered how much the rate of spinning dominates the terms as it rises. So if you have a very fast spinning robot (you know who you are ) even mounting the the gyro pretty close to center will lead to more accumulated error than you'd want if trying to go with a field-centric control, say. (and of course you need to either scale the output or go with a gyro that won't hit 5v before you hit maximum spinning speed)
Thanks for the analysis!
Unread 10-02-2011, 16:41
Ether's Avatar
Rookie Year: 1969
The closer the gyro is to the center of rotation, the smaller "r" is, so the radial acceleration becomes negligible.
Unread 10-02-2011, 13:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
For most yaw rate sensors, in most situations we're likely to encounter in FRC, it shouldn't matter. The entire robot is turning at the same rate. But in extreme conditions, linear acceleration can interfere with the ability of the sensor to measure the yaw rate. If you put the sensor far from the center of rotation, centripetal acceleration could result in inaccurate values being provided.
For example, the ADXRS300 datasheet says that a linear acceleration will cause a false response of 0.2 °/s/g. It's not much, but it introduces a rotational bias that can look like gyro drift as the sensor turns first one direction, then the other.
