Go to Post So every 3 years robots have to lift robots? There's yet another pattern to consider. :p - ruacubfan2 [more]
Unread 05-02-2011, 15:51
Triapod Triapod is offline
Triapod is an unknown quantity at this point
PID Inputs and Outputs
I am wondering if the inputs into the PID SubVI need to be scaled in order to match the output. Can you simply, for example, have a process value that is an angle measure (using an encoder) and a setpoint that is an angle measure and have the control output a value that controls the motor speed, in which case the control accounts for the change in angle based on adjusting the motor speed. The output range also being -1 to 1 to match the motor.
I'd imagine in this case a small proportional gain would be needed since the error in the angle in degrees may be quite large and a small change in the motor speed accounts for a large change in the angle.
Something like:
****The encoder distance will be changed into an angle like in the example motor with encoder vi
Thank you
Unread 06-02-2011, 10:29
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Re: PID Inputs and Outputs
Im not 100 percent if it works yet but that is what I am doing. Just taking the value straight from the encoder into the PID VI. I mean it should work because the error (difference in where you want it and where it is) is derived from the values your giving it so as long as the process value can possibly equal the setpoint (ex. your process value is between 1 and -1 and your setpoint is between 2 and -2).
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 06-02-2011, 13:29
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The setpoint and the feedback (process variable) need to be compatible, with the same scale. The PID is going to try to drive the output until the inputs match.
Unread 06-02-2011, 14:36
I am wondering if the inputs into the PID SubVI need to be scaled in order to match the input.
I meant output there
I did make the setpoint and the process variable the same scale by having the second Encoder Get wired to the shift register, but the main concern is whether it is a problem having the PID control a speed based on an error in angle.
My process value and outputs are angle so they can by as high as 90 degrees or more. Its the output range that I've limited to -1 to 1 in order to match motor speed.
Unread 06-02-2011, 14:40
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Not a problem at all. As you've observed it will simply effect the magnitude of the gains.
Unread 07-02-2011, 20:27
Thank you for the responses. The method works -- just needed to be careful of the integral gain that caused a periodic motion.
Unread 08-02-2011, 02:39
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
I recommend removing the error wire between the Motor SetOutput and the Encoder Get. This will allow those two independent operations to run in parallel.
-Joe
Unread 08-02-2011, 09:28
-Joe
I thought to get the new encoder value right after the motor input has been sent from the PID in each iteration. I'll see if it makes a difference
Also in the image, the encoder should be started
