Go to Post When's the last time you called up FIRST headquarters just to say thanks? Or saw a volunteer at a regional and said, 'Hey, you're doing a really great job here. Thank you for everything you're doing in your spare time.' - Amanda Morrison [more]
Unread 05-02-2011, 17:27
tjakowenko tjakowenko is offline
AKA: Tom Jakowenko
no team (Pirates of the Pythagorean)
tjakowenko is an unknown quantity at this point
how do you code a servo to run continuously
We are using a servo to move an arm and want to command the servo to turn until triggered to stop. We're not sure how to do this using either set() or setAngle. Those commands will move the motor a fractional rotation, but not spin continuosly. Can someone provide a little insight as to command a servo from a pwm output to turn continuously, at different rates of speed and in different directions?
Thanks in advance...
