Go to Post 'We're back to square one! and while we're at it, let's redesign square one.' - Bethie42 [more]
Unread 05-02-2011, 20:19
Team3764's Avatar
Team3764 Team3764 is offline
FRC #3764
Team3764 is an unknown quantity at this point
Question Programming a spike relay in labview
We are trying to program a relay in labview to activate our arm at the touch of a button. However we cant get the spike relay to respond. We can do everything with a jaguar so we think its our programming. Diagramns would be most appreciated.
The Robot chose you...
Unread 05-02-2011, 20:54
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Talking Re: Programming a spike relay in labview
Are you using the Relay palet in the WPI robotics library?
Expect the best, Prepare for the worst
Unread 05-02-2011, 22:13
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
How do you have the Spike connected? Where are its control wires coming from?
Unread 07-02-2011, 06:33
AndrewD's Avatar
AndrewD AndrewD is offline
Programming/Electrical Mentor
AKA: Andrew Dolio
FRC #1243 (Dragons)
Rookie Year: 2010
AndrewD is an unknown quantity at this point
do the pwm channels correspond in the code and electrical systems?
____________________________________________
FRC Team #1243 - The Dragons
Unread 07-02-2011, 08:40
AKA: Jon
Yes, but the spike needs to be set on a relay so the pwm wire will go from relay 1 on the sidecar to the spike not from pwm 1
Unread 07-02-2011, 09:18
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
I hope not, since spikes do not use the PWM outputs.
Unread 07-02-2011, 13:53
AKA: Jon
Let me better state this
The PWM's do correspond in electrical and code but only for motors and servos.
Relays use PWM cables but are plugged into the relay ports on the digital sidecar
Unread 09-02-2011, 09:36
Team3764's Avatar
FRC #3764
Thumbs up Re: Programming a spike relay in labview
We got the relay to work. We had some wires connected incorrectly and fixed the programming for the button controls.
