Go to Post My crotchety old person opinion is that it should be illegal to try to win the award. Do things because you like doing them or because it helps others. Don't do things to win awards. - Madison [more]
Unread 05-02-2011, 20:55
Free Willy's Avatar
Free Willy Free Willy is offline
Team Role: Leadership
Free Willy is an unknown quantity at this point
Minibot fuse
We have been have been having some trouble powering our minibot because we keep blowing the fuse on the battery. We have 2 motors connected in parallel to the tetrix battery pack. Has anyone else been having similar problems? How do you suggest fixing it?
Unread 05-02-2011, 20:57
theschell theschell is offline
FRC #0768
theschell is an unknown quantity at this point
Re: Minibot fuse
Free willy,
We have had that problem once. That was due to our motor releasing magic smoke. So we burned the motors and the fuse.
Unread 05-02-2011, 23:45
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Re: Minibot fuse
If you are stalling out the motors you may be getting close enough to blow the fuse. Also make sure you don't have any shorts causing too much current to flow through.
Another option would be to buy the thermally protected tetrix wires which have a auto reseting device in them, ideally your motor would stop before your main fuse blew.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 06-02-2011, 02:06
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Minibot fuse
We tried to protect the motors by lowering the battery fuse from 20 to 7.5 amps. Today we smoked a motor (but it still works) and didn't blow the fuse. The minibot got up the pole in 2.6 sec but not sure if the motor is 100%. We have the Tetrix PTC but the spec is 2.5 amps at .4 sec as I recall so we thought it wouldn't deliver the optimum current since we are designed to work at peak power which requires ~3.75 amps.
Maybe we will try the PTC afterall.
Unread 07-02-2011, 22:35
AKA: Chris
FRC #0599 (Robodox)
Re: Minibot fuse
Update: Well, we did blow the 7.5 amp fuse today when the limit sw failed to shut off the motors. We got smoke again on two more motors....ouch!!! There went the spares. So... maybe 5 amp fuse?? Looking at the Littlefuse time to blow curves, it will probably blow half the time, just when you need it. Probably need a 6 amp fuse which I don't think anyone makes ... at least for standard auto blades.
Unread 14-02-2011, 18:14
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
Team Role: Mechanical
Rookie Year: 2011
swwrobotics is an unknown quantity at this point
Re: Minibot fuse
Our team blew a fuse when trying to charge the battery. Anyone having trouble like that?
