Go to Post Engineering is a big, big type of fishing to teach. Inspiring kids to study it in college might be more practical. - connor.worley [more]
Unread 05-02-2011, 21:27
Blazanax's Avatar
Blazanax Blazanax is offline
FRC #2443
Blazanax is an unknown quantity at this point
Need help with the e4p encoder!!!
Can you install the e4p encoder without the base? If yes, how can you install it?
Edit: Oh god, no. The triple exclamation points. The minimal use of caps on the topic title. I feel so filthy. I need to stop letting other teammates use my account.
Unread 05-02-2011, 22:10
lightxelle's Avatar
lightxelle lightxelle is offline
FRC #2443 (Blue Thunder)
Team Role: Photography
Rookie Year: 2011
lightxelle is an unknown quantity at this point
Talking Re: Need help with the e4p encoder!!!
I replied! So now,you are not a noob. x]
Unread 05-02-2011, 23:09
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The base of the E4P contains the light source and sensor and the connector for the signals. If you tried to install the encoder without the base, you wouldn't actually have an encoder when you were done.
Unread 05-02-2011, 23:38
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Unless you are talking about the plastic thing that is made to screw into a toughbox? I think it is separate from the encoder chip but you may run into issues with your encoder chip and disk spinning.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 07-02-2011, 00:23
CJmango's Avatar
CJmango CJmango is offline
AKA: Christopher Jones
CJmango is an unknown quantity at this point
Send a message via AIM to CJmango
Given the discrepancy of interpretation, maybe you can post a picture of the part you are considering removing?
The purpose of the black plastic shell is to keep light out so it doesn't interfere with the photodiode inside the encoder. If you can make sure that no outside light gets into the green board, you should be alright to remove it.
Unread 07-02-2011, 00:29
zbanks zbanks is offline
AKA: Zach Banks
FRC #0529 (Mansfield Hornets)
Team Role: Leadership
zbanks is an unknown quantity at this point
Send a message via AIM to zbanks
There are two bases that you could be talking about.
The circular black piece that matches the green PCB helps shield the sensor from light, as others noted. There really shouldn't be any reason to remove it since it's pretty thin and just about the same size as the PCB itself.
There is also a triangular piece that the former piece can screw into for mounting on a transmission. This piece is unnecessary. This year, they weren't even in the KOP since the CIM-ple trannys have the correct mounting holes to begin with.
