Go to Post Please drill responsibly! - IKE [more]
Unread 06-02-2011, 17:06
SCarlos SCarlos is offline
FRC #2815
SCarlos is an unknown quantity at this point
Uploading Code
I'm with Team 2815 and we've been having trouble deploying our code to the robot. When we deploy the code to the robot we get communication but no robot code. Can anyone help us out?
Unread 07-02-2011, 07:57
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Re: Uploading Code
A) Reboot the Robot (worked for us)
B) Reflash the cRIO to v27
C) ???
Unread 07-02-2011, 20:23
Arjun Namineni Arjun Namineni is offline
FRC #4384
Team Role: Coach
Rookie Year: 2010
Arjun Namineni is an unknown quantity at this point
Re: Uploading Code
The same EXACT thing happened to me the other day and I racked my brain for 5 hours trying to figure it out. As it turns out, all you need to do is re-image the cRio to this year's image.
2009-2013: FRC 226 - Student
2014-Present: FRC 4384 - Mentor
Unread 08-02-2011, 19:10
FRC #2815
Re: Uploading Code
We have reimaged the crio several times and got all the updates and we still got no code. We decided to use virtual box to try to deploy the code, but now we can't see the crio under network connections. Please could you tell us step by step exactly what you did?
Unread 08-02-2011, 20:20
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Uploading Code
There are many possibilities why your code doesn't deploy. To really find out what's wrong. You need to hook up the debug console through RS232 cable or use the netconsole app. But once you have a debug console, you will see the spew from the cRio while it boots. This will tell you exactly what failed. In our case last year, it was saying our code exceeds the call distance so we need to add a "-mlongcall" to our linker option.
