Go to Post The question is like asking "Is it better to drive by looking at a map the whole time or by remembering where you want to go and watching the road instead?" - lukevanoort [more]
Unread 07-02-2011, 15:54
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
Rookie Year: 2007
captainking is an unknown quantity at this point
Light Sensor Problems
So we wired up our photosensors (Brown and Blue to + and -, white signal on pwm, and black unused), they turn on and the lights change on them when the light source changes, I plugged them into the same DIO ports I assigned them in LabVIEW, yet they all return false no matter what.
I've provided my code just in case it's that, but any help would be appreciated.
Name:	light tracker begin.JPG
ID:	10016  Click image for larger version
Name:	light tracker teleop.JPG
Integrity first
Service before self
Excellence in all we do
Unread 07-02-2011, 16:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Light Sensor Problems
Your code has two problems.
The name you assign to the refnum is case-sensitive. You have lowercase "light" where you get the refnum, but you used uppercase "Light" when you set it. Fix them to match exactly.
The other problem is something I can't pin down exactly right now, as I don't have access to LabVIEW. Notice those little red dots on your DIO Open? They're telling you that what you have connected to the function doesn't match the kind of thing it's expecting. It's possible that you accidentally wired up the DIO number constant to the module number input.
