Go to Post You people are weird... Now if you'll excuse me, I have some code to debug and I need to figure out where to get tank tracks. - sciguy125 [more]
Unread 07-02-2011, 16:26
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Rookie Year: 2011
Biolore is infamous around these partsBiolore is infamous around these parts
Mounting an Omniwheel
So... We got omniwheels, and want to mount them. Unfortunately, we don't know what we need to mount them. The baring can just fall out. We got spacers to mount sprockets, but they don't keep it in place either. What do we need to mount them?
Unread 07-02-2011, 16:40
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Rookie Year: 2007
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Re: Mounting an Omniwheel
We need a little more information. What type of omniwheels are you using, what type of drivetrain are you using (live axle or dead axle). My gut says you need a hub but we need more information to know for sure.
Unread 07-02-2011, 16:43
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
Team Role: Leadership
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
Pics would be good too
2010 CO Regional: Finalist
2007 CO Regional: Semi-Finalist
Unread 07-02-2011, 16:45
Lead Programmer
AKA: Josh
Rookie Year: 2011
We are using a (or we want to use) four wheel drive. It is independent of the axel. It's an 8" aluminum omniwheel. In the picture on Any Mark, the baring is just sitting in the middle, but it doesn't stay. http://www.andymark.com/ProductDetai...Code=am%2D0431
Unread 07-02-2011, 16:46
Lead Programmer
AKA: Josh
Rookie Year: 2011
The wheels are independent of the axel. We are using four wheel drive, 2 of them are omniwheels. http://www.andymark.com/ProductDetai...Code=am%2D0431.
Unread 07-02-2011, 16:49
AKA: Bryan
Are the omni's powered?
Unread 07-02-2011, 16:52
Lead Programmer
AKA: Josh
Rookie Year: 2011
Yes, the omniwheel are powered
Unread 07-02-2011, 16:55
Dr Theta's Avatar
Lead Mentor
AKA: Derek Messer
Rookie Year: 2007
So it is a dead axle system, I do not personally have experience with these particular wheels however it appears that the bearings are a press fit to the center, you mount the spacers and sprockets to the wheel with bolts through the mounting holes.
Unread 07-02-2011, 17:00
Lead Programmer
AKA: Josh
Rookie Year: 2011
Yeah, the barings go into the center and they don't just slide, but they can easily be removed, like when test drove the robot before we got the sprockets, and the omniwheels came off.
Unread 07-02-2011, 17:02
Dr Theta's Avatar
Lead Mentor
AKA: Derek Messer
Rookie Year: 2007
Did the wheel come off the bearing or did it come off the chain? Are you using spacers on your axle to ensure the wheel can't move laterally during operation?
Unread 07-02-2011, 17:04
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
We have used these before, 6 inch version. How we mounted them on a dead ale system was using flanged Bearings similar to these: 6384K348
I would recommended purchasing these as the quickest solution.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 07-02-2011, 17:05
AKA: Bryan
If the bearings are falling off then you need longer spacers to hold them in there or you need to fabricate some screws in the wheel to told them in
So it should look like
Frame| Spacer| Bearing | Wheel | Bearing | Spacer | Frame
The spacers should be long enough so that the wheel barely moves side to side
does that answer what you were asking?
Unread 07-02-2011, 17:08
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Rookie Year: 2007
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
I have a feeling that you're not using any spacers on your axles. Try cutting some PVC pipe to length to slide over your axles to keep the wheels in the same place, it'll also keep the bearings from sliding out because theres PVC pipe in the way....
Should be like this
| is sprocket
- is axle
= is spacer
|| is wheel
Unread 07-02-2011, 17:10
AKA: Bryan
PVC works great for this but make sure the pipe rubs against the bearings and not the omnis... we have found that some Aluminum pipes that we cut ourselves work for this due to the thinner wall then pvc
  #15   Spotlight this post!
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
viperred396 is correct, spacers will probably be your quickest solution.
You can also use shaft collars to stop the wheels from traveling latterly and prevent the bearings from falling out.
