Custom Dashboard
Out of curiosity, would it be possible to add a countdown clock to the dashboard? This would be a great help to avoid having to look up to find the main clock to find the time left in the round. Any suggestions?
Re: Custom Dashboard
I think it is a good idea, provided you keep the other info on field timing in mind.
The LV numeric has a relative time display format which will format into min.sec.frac, and what you'll wire is the result of teleOpLength{seconds} - (currentTime - teleOpStartTime){seconds}. You can change the font to make things larger. If you need more help, there is a tutorial on making a custom dashboard available from ni.com/frc, and I believe from frcmastery too. Greg McKaskle |
