Go to Post In other words, don't count your chickens before they hatch, even if the shell seems broken. - Lil' Lavery [more]
Unread 07-02-2011, 19:26
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Camera
Hello this is the first year we are trying to use the camera but when we plug the camera into port #2 on the cRio, the lights dont blink, im assuming this is a problem we are using a crossover cable, are we supposed to ethernet?
Unread 07-02-2011, 19:34
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Camera
What lights are you talking about? If they are the camera lights you need to plug it in to the power distribution board first.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 07-02-2011, 20:02
AKA: Garty
Re: Camera
im talking about the ethernet light ports like you see on the back of a comuputer that are orange and green i think? they blink to show a connection and right now they are not blinking for us but we have connection just not to the camera or do they just not blink?
Unread 07-02-2011, 20:12
Arjun Namineni Arjun Namineni is offline
FRC #4384
Team Role: Coach
Rookie Year: 2010
Arjun Namineni is an unknown quantity at this point
Re: Camera
Yea I think you are supposed to use Ethernet. Try that and see if it works.
2009-2013: FRC 226 - Student
2014-Present: FRC 4384 - Mentor
Unread 07-02-2011, 21:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Camera
You do have to use a crossover cable. Neither the cRIO nor the Axis camera is capable of "switching sides" to let you use a standard patch cable.
Do you have the camera connected to power? If so, what color is the ring around its lens showing?
If you're talking about the green connection/activity LED next to the Ethernet jack, is it not lighting up at all, or is it just coming on steady and not blinking?
Do you have software loaded into the cRIO?
Unread 07-02-2011, 21:16
AKA: Garty
Re: Camera
The camera is connected to power.
The Ring is green.
The lights arnt coming on, on the connection LED.
yes the cRio is updated to v.27 and the code is deployed onto the cRio
any ideas on why?
Unread 07-02-2011, 21:41
Software Architect
Re: Camera
The crossover cable might be faulty. Can you test it? For example, you might use it to connect your computer directly to the camera and view the camera's web interface.
Unread 07-02-2011, 21:44
AKA: Garty
Re: Camera
i used the same crossover cable to set up its setting but i did realize i didnt set one of the settings so i better try that tomorrow, because im at home now! but good thing is its a 2 hour late start tomorrow!
